  4. ABB Robot Forum
Rapid Programing
  • Enio
  • July 30, 2024 at 11:14 AM
  • Enio
    189
    Hello guys, I need some advice. I am working in a Irc5 welder with IRBP type D positioner. The part I need to weld is a plate with a bush mounted in the center of the plate. My problem after programming the robot target with the welding torch straight with Z during the execution the torch changes the inclination following the table rotation. Is there any instruction to prevent the torch from movingRoutine2.txt when the table is rotating?
  • ColoradoTaco
    16
    103
    • August 1, 2024 at 4:45 PM
    Your robtargets are tied to WobjSTN1. That means that as your positioner (STN1) moves, the robot will reorient to stay with it.
    Do you have coordinated motion established? It's been awhile since I dealt with positioners, but if you want the robot to move independently of the station or vice versa, you will need to turn coordinated motion OFF. (Or do a MoveAbsJ and only modify the positioner values, but that can get weird)
Similar Threads
  • Rapid Programing
    • Enio
    • July 26, 2024 at 4:15 PM
    • ABB Robot Forum
  • G-code from Cura to Rapid using Python
    • bucomir
    • March 15, 2022 at 6:13 PM
    • ABB Robot Forum
  • Are higher-level proprietary programming languages bad for developing programming skills?
    • IsaacMaw1
    • May 11, 2024 at 5:31 PM
    • General Discussion of Industrial Robots Only
  • Buy old robot, programing, 2D/3D file, first buy
    • Swebot
    • October 14, 2021 at 2:34 AM
    • ABB Robot Forum
  • Basic Programing Rapid
    • Duminda
    • February 27, 2024 at 11:32 AM
    • ABB Robot Forum
  • RobotStudio Issue (Rapid)
    • Pedro Glez Soto
    • March 3, 2022 at 9:41 PM
    • ABB Robot Forum
  • Bit of a coding Conundrum
    • Ash
    • January 31, 2022 at 6:25 PM
    • KUKA Robot Forum
  • Config Suction Cup YCR1000
    • IRS
    • October 22, 2021 at 2:51 PM
    • Yaskawa Motoman Robot Forum
  • Rapid programming
