Hello, I have a strange problem. After power shut down the CR4 motherboard Fujitsu-D3445-K1 (Skylake) can't start/boot from internal PSU. 27V is ok at connector. Appear the HW MON Fault red, but Green led is ok close to cmos 3V battery. And 3.3V on LDO is ok Close to CMOS battery. CMOS battery changed. When Main power switch is on, spin up the CPU cooler 0.5sec (power from mainboard) and stop, but thats all. Anyway other parts(Robot control etc) looks like works well.
If try external PSU (ATX connector) That is start booting normally ..Bios windows etc...looks like good.
Where find Motherboard manual PDF?(details)
Anyway How is start the Mainboard? Like Wake on lan?
And found an jumper close to lan ports, what is that? Where is the Bios/cmos reset?
What should be check or set in bios?
Where can I find Bios update file?(fujitsu hompage just D3445-S)
