Hello everybody we changed the krc4 compact Ip to auto and now we can't use the smartpad anymore. Smartpad says cannot communicate with krc4 and probably their ips are different. Can anyone help us to solve this problem? We tried lots of thing thanks to this forum.
Kuka Smart Pad 2 is not connecting to the Krc4 compact
kukauser1 -
July 23, 2024 at 5:34 PM -
SkyeFire
July 23, 2024 at 5:42 PM Approved the thread. -
Which IP? How? Did you do it through the KUKA HMI menus, or did you go directly to Windows and change the IP setting there?
What did you try? Not telling us that is a recipe to have us waste our time suggesting things you've already tried.
Generally, when someone does this, the fix is to do a complete KSR Restore from the KSR backup you made before tampering with system settings. You did make a KSR backup first, yes?
Yes we changed the windows ip to automatic and now the smartpad cannot connect to the krc. We tried the suggestions who also asked this forum. Sorry about the low info about the problem. IMG_2757.jpgIMG_2757.jpgIMG_2756.jpg Our problem looks like that. Smartpad cannot see the krc. We changed back to the standart version of the ip but it didn't connect each other. We tried to factory reset of smartpad which we pressed the menu button and the second axis +- buttons at the same time. But the factory reset give an error while reseting it says bad block and it skipped that 17%.
Why? The SmartPad is not the problem. The problem is that you changed the IP of the KRC, and you'll probably have to do a full KSR restore of the KRC.
Wel, you may have destroyed the SmartPad. But until you fix the KRC, there's no way to be sure.
