Mapping I/O KRC5
  • Ilya Smolin
  • July 23, 2024 at 2:29 PM
  • Ilya Smolin
    15
    Hi, my question maybe stupid. I am trying to find a way to read IO signal from KRC. I am already reading some IO, with SYS-X48 Interface Board Standart, but from I have seen - it has 16 inputs and 16 outputs that you can map. I have 32 signal, that I also want to map. I know, that previously in my company they used easycat shield for the arduino, connected somehow to KRC4. But unfortunately it is a lost knowledge. I will attach current configuration of my KRC and Bus componens. How can i output 32+ I/O, do I need some additional boards to connect to KRC?
  • panic mode
    1,280
    13,083
    • July 23, 2024 at 3:14 PM
    i would recommend to simply use bus coupler EK1100 and then add individual input and output modules as needed. this is expandable, very simple to configure and low cost.
    an EL2809 is an output module (16 DO)
    so
    EK1100 + EL2809 + EL2809+...
  • Ilya Smolin
    15
    • July 23, 2024 at 3:44 PM
    Sorry, probably was unclear in my question, but the EL2809 module as i see gives me physical IO, but I just wanted to read the IO outputs from my pc
  • panic mode
    1,280
    13,083
    • July 23, 2024 at 4:31 PM
    ok... so it is just matter of accessing them from your PC. i guess that is what the Arduino with EtherCat shield did. this should be straight forward as all files and code are readily available:
    EtherCAT® and Arduino
    EasyCAT - AB&T
    it depends on what the intent or goal is but another option is to not have any additional hardware. just run program on a PC and have ethernet cable connecting PC and KRC....
Similar Threads
  • Integration of Kuka KR C5 and Fronius TPS 400i using PROFINET
    • postek
    • August 30, 2023 at 8:50 PM
    • KUKA Robot Forum
  • KRC5 Profinet IO Device not reachable
    • luccaleao
    • August 3, 2021 at 9:26 PM
    • KUKA Robot Forum
  • KRC5 Micro with Agilus KR6
    • SkyeFire
    • June 17, 2022 at 5:04 PM
    • KUKA Robot Forum
  • Power on spindle
    • Uros Marinkovic
    • January 9, 2024 at 2:00 PM
    • KUKA Robot Forum
  • KUKA KRC5 Anybus Ethercat Configuraion
    • GriF
    • August 26, 2023 at 2:26 PM
    • KUKA Robot Forum
  • Rockwell point IO (1734-AENTR) Conecting with KRC
    • kinder_br1
    • February 22, 2023 at 10:06 PM
    • KUKA Robot Forum
  • Kuka Robot Communications with LabVIEW
    • cowen
    • August 3, 2022 at 8:53 AM
    • KUKA Robot Forum
  • Inputs and outputs with a PLC
    • Andres
    • July 13, 2021 at 7:10 PM
    • KUKA Robot Forum
  • IO
  • EtherCAT
