Determining the Date from CREATE and MODIFIED in TP *.LS Files
  • cattmampbell
  • July 18, 2024 at 5:24 PM
  • cattmampbell
    17
    I'm trying to programmatically parse the date from the CREATE and MODIFIED in TP *.LS files, but I am having a difficult time determining the year, month, and day because they are formatted as 2-number values separated by a - character, for example:
    CREATE      = DATE 23-09-24  TIME 18:48:42;
    MODIFIED    = DATE 23-09-24  TIME 20:53:32;
    In the example above, the first (23), second (09), and third (24) 2-number values could be the year, month, or day.
    Writing logic to determine if a 2-digit number is greater-than 99 (not the year), greater-than 12 (not the month), greater-than 31 (not the day), does not cover the example above considering:
    • The first (23), second (09), and third (24) 2-number values could be the year (less-than 99).
    • The first (23), second (09), and third (24) 2-number values could be the day (less-than 31).
    • The second (09) 2-number value could be the month (less-than 12).
    I checked the ERR*.LS files from the same Robot to see if the formatting was the same, but it uses a 2-number value for the day, a 3-letter value for the month, and a 2-number value for the year, for example:
    851752" 15-OCT-23 20:10:10 " APPL-175 Backup started           " " WARN 00000000" "
    851753" 15-OCT-23 20:01:10 " APPL-176 Backup finished          " " WARN 00000000" "
    851754" 15-OCT-23 19:54:26 " SDTL-115 Data Output is completed " " WARN 00000000" "
    I found many examples in the Version 9.30 of the HandlingTool Manual, but the formatting is different as it uses a 2-number value for the day, a 3-letter value for the month, and a 4-number value for the year, for example:
    Creation Date:     21–FEB-2006
    Modification Date: 21–FEB-2006
    In Version 9.30 of the HandlingTool Manual, Creation Date is described as:
    Quote
    Creation date is the date on which the program name was created.
    In Version 9.30 of the HandlingTool Manual, Modification Date is described as:
    Quote
    Modification date is the date, according to the calendar in the controller, when the file was last displayed in the editor. This information can be displayed using the [ATTR] function key on the SELECT menu.
    Is there a System Variable or a setting that determines how the year, month, and day are formatted in the CREATE and MODIFIED in TP *.LS files?
    Edited once, last by cattmampbell (July 19, 2024 at 6:01 PM).
  • AnandTUD
    42
    • July 19, 2024 at 9:24 AM
    If I am not wrong, the format in CREATE and MODIFIED is DATE YY-MM-DD TIME HH:MIN:SS;
    You could use Karel to get more info using GET_ATTR_PRG and CONV_TIME_STR functions.
  • DS186
    200
    1,075
    • July 19, 2024 at 10:43 AM
    Quote from AnandTUD
    You are right. This is the correct format used for date and time.
  • cattmampbell
    17
    • July 19, 2024 at 4:27 PM
    Quote from AnandTUD
    AnandTUD This means the examples from the HandlingTool Manual are more like pseudocode than they are applicable/loadable examples?
    If this is the case, it looks like Process Simulate exports *.LS files with incorrectly formatted CREATE and MODIFIED values, for example:
    CREATE              = DATE 2023-12-07  TIME 09:44:02;
    MODIFIED            = DATE 24-07-19    TIME 10:10:14;
    I imagine the TP interpreter would be able to accommodate similarly formatted CREATE and MODIFIED values, or someone else would have posted a similar question before I did.
    Thank you!
    Edited once, last by cattmampbell (July 19, 2024 at 6:03 PM).
  • DS186
    200
    1,075
    • July 19, 2024 at 8:49 PM
    If you enter the DETAIL screen of a program in the Teach Pendant SELECT menu, the format of date and time looks like this:
    If you open a *.LS program with a text editor, the format of date and time looks like this:
  • tp
  • Syntax
