Backups option
  • Nsparks2
  • July 18, 2024 at 1:51 AM
  • Nsparks2
    Trying to do 6 month image backups. Put my USB in UD1. Try to pull image backup and it only gives me the option for MC: memory card. When I do just “all of the above” for robot files they go to the thumb drive, but the image will not let me choose UD1.
  • Nsparks2
    • July 18, 2024 at 2:06 AM
    Yes I did set my device correctly and directory.
  • Roland Keller July 18, 2024 at 8:29 AM
    Approved the thread.
  • Nation
    Typical Robot Error
    529
    1,908
    • July 18, 2024 at 2:29 PM
    What is your controller version?
  • Nsparks2
    • July 19, 2024 at 9:10 PM
    R30i-a I believe
  • pdl
    266
    1,506
    • July 19, 2024 at 9:31 PM
    Image backups weren't supported over USB until the R-30iB controller.
    I'll still use a memory card over USB whenever I can't use FTP, unless it's only a file or two. I've had WAY too many issues with USB, even when using the memory sticks that come from Fanuc.
  • AlanL
    22
    77
    • July 22, 2024 at 2:23 PM
    As long as you have an image there really isn't a need to ever take another unless you do something like add an option. If you need to do a restore you can just put in an old image and then immediately put an AOTA to get up to date programs.
  • 00Red
    14
    13
    • July 23, 2024 at 3:09 PM
    Quote from AlanL
    While there might not be a need to take another image unless you add an option or change a system variable, what would you rather load: an image from this year, or one taken 5 years ago?
    I take an image backup and a copy backup at the beginning of each year, cheap insurance is the way I look at it.
    It's always the robots fault, just ask management!
    Robots are always the solution, just ask management!
Similar Threads
  • Image backup for ABB robot?
    • Imran Khan
    • July 8, 2024 at 8:03 PM
    • ABB Robot Forum
  • ABB IRC5 Backup .TAR file format
    • MasterGrogu
    • February 26, 2024 at 10:56 PM
    • ABB Robot Forum
  • Frame data from backups?
    • SkyeFire
    • July 9, 2020 at 3:22 PM
    • Fanuc Robot Forum
  • Setup and Perform Image Backups over TCP on laptop
    • MechatronicsDude
    • November 30, 2023 at 11:45 PM
    • Fanuc Robot Forum
  • Main difference kuka/fanuc, "Tribal knowledge" and generic good to know fanuc stuff
    • Hes
    • November 3, 2023 at 6:56 PM
    • Fanuc Robot Forum
  • Kuka tool no.3: Kuka Archiving Automation
    • asimo
    • May 1, 2009 at 7:53 PM
    • Manuals, Software and Tools for KUKA Robots
  • EtherCAT timeout / No connection to KRC
    • rydeck
    • August 11, 2020 at 8:29 PM
    • KUKA Robot Forum
  • Is it possible to automate the backups generation while working in RobotStudio?
    • robotecnik
    • May 23, 2022 at 10:29 PM
    • ABB Robot Forum
  • Date/Time Reset on Power On/Off
    • rstrand
    • October 16, 2020 at 12:30 AM
    • Kawasaki Robot Forum
  • backup files
Users Viewing This Thread
  • 1 Guest
