I myself have some experience with robot mastering using an EMD toolkit on Kuka. However, I'm now working in a team of engineers who have no experience with robots, and we're trying to design a custom robot. They don't seem convinced on the need for doing mastering the proper way (i.e. using an equivalent of an EMD toolkit).
I feel like I'm not providing a solid and convincing explanation of why mastering is critical for precise positioning.
I myself understand that mastering calibrates the mechanical zero and the electrical zero. The crucial part of using an EMD toolkit, is to have each motor move its load (i.e. rest of the arm plus whatever tool payload) when setting the zero position.
My coworkers are suggesting to simply manually line up each pair of axes to matching witness marks with the motors powered off, and then powering up the motors and recording the encoder position as zero.
I tried my best to explain that manually moving de-energized motors to line up the axes doesn't serve the purpose of mastering. I tried explaining that the zeroing with load is not the same as zeroing without load (giving the classic Kuka example of a fishing rod). Am I wrong?
Is it possible to achieve true zeroing by simply manually lining up the de-energized axes, and then recording the encoder values?
Is there a resource/textbook that explains mastering with solid theoretical backing?
Thanks!
