I recently encountered a situation where I had to switch between user frames and tool frames while working with a robot. Initially, I set up a user frame for a fixture, but I faced challenges when trying to align the end effector with a specific point on the fixture. As a result, I switched to the tool frame without a clear understanding of the implications.
Can someone provide insights on how to effectively utilize these frames? Should we switch frames based on the robot's movement, or is it sufficient to stick with one frame throughout the entire code? Thank you for your assistance.
