MAP A DO TO A SPECIFIC ALARM
  • PaulG
  • July 10, 2024 at 3:11 PM
  • PaulG
    5
    Hi everyone,
    I want to activate a DO when a specific alarm occurs.
    In my case, I want to activate a DO when the SRVO-065 BLAL alarm (Group:%d Axis:%d) occurs, to tell operators that the batteries have to be changed, with a message on a HMI. Only this one in particular.
    Do you know if there is a way to do this ?
    Thank you in advance !
  • Roland Keller July 10, 2024 at 3:40 PM
    Approved the thread.
  • HalbesYoyo
    Persona non grata
    49
    151
    • July 10, 2024 at 4:11 PM
    Have a look here: The meaning of $ALM_IF.$LAST_ERCODE ?!
    It should contain anything you need. :winking_face:
  • DS186
    201
    1,076
    • July 10, 2024 at 4:15 PM
    Simply use the UO BatAlarm from the UOP signals. This one does exactly what you want.
  • PaulG
    5
    • July 10, 2024 at 4:48 PM
    DS186,
    Well, it would work and that is what I was about to do. But I really want this alarm only.
    If I link the UO BatAlarm to a DO, it will activate also when I get a BZAL Error for exemple, and I don't want it (I want a specific message to display on the HMI depending on a specific alarm).
    Thank you for the fast answer.
    Halbes,
    It means that the system variable $ALM_IF.$LAST_ERCODE displays the code of the last error that has occured, right ? So the BLAL Alarm must have a ERCODE right ? Where do you find it ?
  • DS186
    201
    1,076
    • July 10, 2024 at 5:19 PM
    The alarm code for the BLAL alarm is SRVO-065. Everything you need to know is described in the thread from HalbesYoyo .
    Quote from HalbesYoyo
  • PaulG
    5
    • July 15, 2024 at 1:56 PM
    I almost understood all the thread I guess. The thing I don't get now, is how to get the different MSBs ?
    From MOTN-018, you get 15-018. That gives 0x0F - 0x012 in hex. But then, the last ERCODE is 0x26_0F_0012. Is it possible to deduct the decimal ERCODE only from "MOTN-O18" ? I don't know where the 26 comes from.
    In my case, I have a SRVO-065, which gives the ERCODE : 0xmm_0xB_0041. What would the MSB be ?
  • HalbesYoyo
    Persona non grata
    49
    151
    • July 15, 2024 at 3:32 PM
    The thread The meaning of $ALM_IF.$LAST_ERCODE ?! lists the meaning of the different bits of the severity in the MSB. They are set by the system depending on the alarm message | alarm type.
    I haven't found any list of severities that belong to specific alarm messages so far.
    Addendum:
    Just wait until the alarm happens and see what you get for the MSB. :upside_down_face:
  • PaulG
    5
    • July 15, 2024 at 3:50 PM
    That is what I was thinking ! I will have to wait quite a long time now to get a BLAL Error. But I keep your thread in mind since it can really be useful. Thank you both for answering !
  • HalbesYoyo
    Persona non grata
    49
    151
    • July 15, 2024 at 4:00 PM
    What may helps will be performing a maintenance backup (MENU > FILE > BACKUP > Maintenance data) to an USB-Stick and look for the file ERRALL.LS in this backup. It contains some more data than what is to be seen at the TPERROR display and/or Alarm History. :winking_face:
Similar Threads
  • Limit switch to limit servo power on
    • PATROLLING
    • January 23, 2024 at 8:18 PM
    • Yaskawa Motoman Robot Forum
  • Trigger an Output signal when E-Stop has been pressed
    • Nox
    • August 3, 2021 at 3:32 PM
    • KUKA Robot Forum
  • Alarm
  • DO
