  4. Comau Robots
Comau Program Template
  • AndreasPoe
  • July 4, 2024 at 8:35 PM
  • AndreasPoe
    5
    Hello everyone,
    Can someone provide me with a program template that utilizes subprograms and calls programs from various files globally?
    I have the programming manuals, but I am struggling to make sense of them.
    I would greatly appreciate any help.
    Thank you!
  • MOM July 4, 2024 at 9:40 PM
    Approved the thread.
  • massula
    200
    8
    1,421
    • July 8, 2024 at 12:42 AM
    I'm assuming You want to write Your programs by hand, instead on the robot itself.
    Here follow an small example.
    PROGRAM MyProg STACK = 2048   -- This is a comment
    CONST
    VAR pnt0009P : POSITION
     xtn0002X, xtn0001X, xtn0003X, xtn0004X, xtn0005X : XTNDPOS FOR ARM[1]
     pnt0004P, pnt0005P, pnt0006P, pnt0007P, pnt0008P : POSITION
     p_f_i_prel, p_prel, pnt0001P, pnt0002P, pnt0003P : POSITION
    ROUTINE CD_End EXPORTED FROM CDetect
    ROUTINE CD_Start(ai_Coll : INTEGER) EXPORTED FROM CDetect
    ROUTINE ToolFrame(ai_tool, ai_frame, ai_arm : INTEGER()) EXPORTED FROM TT_TOOL
    BEGIN
     $STRESS_PER := 50
     $TOOL_RMT := FALSE
     $LIN_SPD := 0.30000001
     $SPD_OPT := SPD_CONST
     $ARM_SPD_OVR := 100
     $ARM_ACC_OVR := 100
     $ARM_DEC_OVR := 100
     $TERM_TYPE := COARSE
     ToolFrame(10, 0)
     CD_Start(21)
     MOVEFLY JOINT TO p_f_i_prel ADVANCE
     MOVEFLY JOINT TO pnt0005P ADVANCE
     MOVE LINEAR TO p_prel,
       WITH $PROG_SPD_OVR = 50,
       WITH $PROG_ACC_OVR = 25,
       WITH $PROG_DEC_OVR = 25,
     ENDMOVE
     CD_End
    END MyProg
    Routines like ToolFrame and CD_Start are inside in other libraries (TT_Tool and CDetect, respectively), so they must be declared on the declaration section of the program.
    Since You didn't told what is the controller You will be using, I'm assuming it is a C5G Plus. So would be a good idea to use WinCRC software to write Your programs, since it can find syntax errors.
  • AndreasPoe
    5
    • July 29, 2024 at 7:05 PM
    Hi, thanks for the example program.
    Yes, we are already using WinCRC, although I don't find it very user-friendly.
    Does it require a special command to make the robot loop continuously? We are using movefly and advance, but the robot stops at each point.
  • massula
    200
    8
    1,421
    • July 31, 2024 at 4:03 AM
    Are using logic commands between these movements?
    If yes, robot will make small stops, and would be better use WITH CONDITION statement in combination with the MOVE instructions.
  • AndreasPoe
    5
    • July 31, 2024 at 9:52 PM
    Between the movements, I only write an integer variable as a reference marker for the home position. If I comment out this line, it doesn't change anything.
    Linear movements work without stopping, but the robot stops during joint movements.
    I will try to post part of the program tomorrow.
  • AndreasPoe
    5
    • August 1, 2024 at 12:27 PM
    ROUTINE mv20VP_10VP
    BEGIN
     ToolFrame(tGreifer, 1, 1)
     $FLY_DIST := 200
     IF $FDIN[doAutoAktiv] = OFF THEN
       MOVEFLY JOINT TO p20VP ADVANCE
     ENDIF
     nActPos := 2010001
     MOVEFLY JOINT TO p10VP_20VP_3 ADVANCE
     nActPos := 2010002
     MOVEFLY JOINT TO p10VP_20VP_2 ADVANCE
     nActPos := 2010003
     MOVEFLY JOINT TO p10VP_20VP_1 ADVANCE
     nActPos := 2010004
     MOVE JOINT TO p10VP
     nActPos := 10
    END mv20VP_10VP
  • massula
    200
    8
    1,421
    • August 1, 2024 at 4:45 PM
    I would try to use WITH or WITH CONDITION clauses.
    Something like this
    ROUTINE mv20VP_10VP
    BEGIN
    $FLY_DIST := 200
    ENDIF
    nActPos := 2010001
        WITH nActPos := 2010002,
    ENDMOVE
        WITH nActPos := 2010003,
    ENDMOVE
        WITH nActPos := 2010004,
    ENDMOVE
    MOVE JOINT TO p10VP
        WITH nActPos := 10,
    ENDMOVE
    END mv20VP_10VP
  • AndreasPoe
    5
    • August 1, 2024 at 8:00 PM
    I will test this, but as I said, converting the assignment into a comment does not improve the situation either.
    Today, I had the robots in remote operation for the first time, and here too, they stop after each joint movement.
    Between my linear movements, the same assignment is made, and it does not cause a stop.
  • Comau
  • Templates
  • pld2
