Movement Stop with Distance Before
  • Okami
  • June 25, 2024 at 8:54 AM
  • Okami
    74
    Hello, dear forum.
    I think I have a misunderstanding on how the DB works on Fanuc...
    I need my robot to open a valve at the beginning of a trajectory, and then close it almost at the end of it without stopping the movement (Imagine that you're painting with an airbrush or spray).
    The trajectory is only a straight line, so it should be easy...
    I tried everything, CNT, FINE, DB, ACC, everything that came to my mind.
    This is basically the code:
    : WAIT 1 (SEC);
    : R[11] = 250;
    : L P[8] R[11]mm/sec FINE DB 0.0 mm, CALL INI_PAINT;
    : L P[9] R[11]mm/sec CNT100 ACC R[4];
    : L P[10] R[11]mm/sec CNT100 DB 0.0 mm, CALL STOP_PAINT;
    : L P[11] R[11]mm/sec CNT100 ACC R[4];
    I know that in KUKA you have an instruction called "CONTINUE" which keeps the logical pointer jumping between trajectories without stopping movements.
    Any of you, smart people, have any idea?
    Thanks.
    :smiling_face:
    "Hell...Yesterday it was workinG... I sweaR" :o)
  • svr
    48
    • June 25, 2024 at 10:39 AM
    I would probably write to you in the same way. what do you have in the ini_paint and stop_paint programs?
  • pdl
    272
    1,549
    • June 25, 2024 at 3:25 PM
    Do your start and stop programs have motion groups assigned to them?
  • FC2
    • June 25, 2024 at 3:26 PM
    Are you able to share what the INI_PAINT and STOP_PAINT programs look like?
  • 1Cliff
    • June 26, 2024 at 9:35 AM
    As already written:
    We need to know the 'helper programs'
    Distance Before (DB) is not stopping the motion by it own...
  • hermann
    412
    2,629
    • June 30, 2024 at 12:33 PM
    But the 'FINE' in line 4 stops.
  • HawkME
    570
    3,270
    • July 1, 2024 at 2:53 AM
    It won't work correctly with CNT, only with FINE. Can you move your P[10] further away and then use DB with Fine? If that isn't an option then the only other way I can think of is to monitor the position in BG logic and turn off the spray signal when it's past a certain positional value.
  • hermann
    412
    2,629
    • July 1, 2024 at 5:31 AM
    May be it works with cnt0 ?
Similar Threads
  • DX200: MOVL UNTIL ON... what if doesn't turn on?
    • CrazyHorse
    • February 15, 2024 at 3:10 PM
    • Yaskawa Motoman Robot Forum
  • Max Speed & Acceleration
    • Reckless
    • February 9, 2023 at 7:21 PM
    • General Discussion of Industrial Robots Only
  • Syncronise movement with external axis?
    • RustyTech
    • February 16, 2023 at 5:33 PM
    • KUKA Robot Forum
  • Motion approximation when ARP is stuck
    • mudanda
    • September 16, 2022 at 12:46 PM
    • KUKA Robot Forum
  • RobotStudio Issue (Rapid)
    • Pedro Glez Soto
    • March 3, 2022 at 9:41 PM
    • ABB Robot Forum
  • RSI distance control with ANIN problem.
    • PiotrEDC
    • July 22, 2021 at 6:06 PM
    • KUKA Robot Forum
  • Motion interpolation beetwen procedures
    • Gieniar
    • May 11, 2021 at 3:57 PM
    • KUKA Robot Forum
  • Homing filosophy with Fanuc
    • PetrBroza
    • November 25, 2020 at 10:00 AM
    • Fanuc Robot Forum
  • Different brake reactions when searching for one part
    • robotecnik
    • September 23, 2020 at 10:12 AM
    • KUKA Robot Forum
  • movement
  • db
