I am trying to connect a 5/2 pneumatic valve to the FANUC R-30iB Mini Plus controller. This is how it is IO terminal card looks. When I connect the wires, it does not work. But it worked previously. What could be the possible causes to this?
I was trying to control 2 pneumatic valves from the controller. After I physically connected the wires, I switched on the digital IO ports (DO101 and DO102) from the TP. But nothing happens. Can someone help me? Can someone explain how to connect valves to this PCB and do i need to use jumper wires if so where? Kind of basics. Thank you.
