no more data/variables available
  • m.dinio
  • June 16, 2024 at 10:32 AM
  • m.dinio
    61
     INT OFFSET, BCI
     DECL STATE_T SR_T, SC_T
     DECL MODUS_T MR_T
     REAL TIMEOUT
     MR_T=#ABS
     TIMEOUT=10
     OFFSET=0
    COPEN(:SER_3,HANDLE)
    IF(HANDLE==0) THEN
        HALT
    ENDIF
    LOOP
    IF($DATA_SER3>0)THEN
     CREAD(HANDLE, SR_T, MR_T, TIMEOUT, OFFSET, "%r", BCI);
    ENDIF
    ENDLOOP
    after runnig code this error show:
    and program break.
  • hermann
    412
    2,624
    • June 16, 2024 at 1:40 PM
    You must set offset to zero before every reading with cread.
  • m.dinio
    61
    • June 16, 2024 at 2:35 PM
    Quote from hermann
    i was set in declaration
  • panic mode
    1,296
    13,136
    • June 16, 2024 at 6:02 PM
    you are missing the point...
    offset is incremented by number of characters received every time CREAD is processed so sooner or later you are going to run out of space (buffer array length). to receive again, you need to reset offset value. and this needs to be done over and over... right now your example shows that you reset it once but - you are using CREAD in a loop.
    consider moving line 8 just before line 15 so both are always executed in tandem.
  • hermann
    412
    2,624
    • June 16, 2024 at 11:27 PM
    INT OFFSET, BCI
    DECL MODUS_T MR_T
    REAL TIMEOUT
    MR_T=#ABS
    TIMEOUT=10
    IF(HANDLE==0) THEN
    HALT
    ENDIF
    LOOP
    OFFSET=0
    ENDIF
    ENDLOOP
  • m.dinio
    61
    • June 18, 2024 at 11:11 AM
    thanks panic mode , hermann .
    how can i read from serial in binary format
  • panic mode
    1,296
    13,136
    • June 18, 2024 at 2:21 PM
    you need to receive data, then parse what ever the data is.
    to receive data you need to create a buffer, open channel, fetch data from the channel into buffer, process what is in the buffer, clear buffer, fetch more data etc. the part you seem to be stack on is streaming... as received data is streaming in, you need to process what is already in the buffer and make room for next data to be received. this need to be carefully crafted in order to keep running... if you cannot process the received data in time, use handshaking. this allows you to tell to sender "hold on a minute, i am still busy...". and once you are ready, then negotiate to get some more data. either way this is not trivial. most examples are likely to be very basic. for this to be practical in any way or form, you will need to handle much more, including channel loss, restart etc.
    also you did not state what the received values are and what they are representing so there is no telling how to decode...
  • m.dinio
    61
    • June 18, 2024 at 5:39 PM
    many thank panic mode
  • m.dinio
    61
    • June 29, 2024 at 9:58 AM
    sometimes cwrite command not send , why?
    i using cwrite in sps.src
  • MOM
    176
    7
    1,424
    • June 29, 2024 at 3:54 PM
    Quote from m.dinio
    IN $Config.dat define the variables (here just examples)
    ; --- variables ---
    INT CNT
    REAL VALUES[6]
    In your program
    OFFSET_CR=0
    CREAD(HANDLE,SR_T,MR_T,TIMEOUT,OFFSET_CR,"%r%.6r",CNT,VALUES[])
  • m.dinio
    61
    • June 29, 2024 at 9:49 PM
    • #11
    Quote from MOM
    ; --- variables ---
    INT CNT
    REAL VALUES[6]
    In your program
    OFFSET_CR=0
    thanks,but my problem is cwrite in sps.src
  • MOM
    176
    7
    1,424
    • June 30, 2024 at 12:07 AM
    • #12
    In my post #10 I answered the question of your post #6
    from my point of view: question answered!
  • MOM
    176
    7
    1,424
    • June 30, 2024 at 12:11 AM
    • #13
    Quote from panic mode
    This also is applied to your transmit buffer and I have not seen how your source code looks like.
  • hermann
    412
    2,624
    • June 30, 2024 at 8:41 AM
    • #14
    Quote from m.dinio
    Not enough information for answering.
    You are mixing up different questions in one thread, that's not the best idea.
  • m.dinio
    61
    • July 1, 2024 at 8:09 PM
    • #15
    this is part of my code
    sps.src
    loop
    IF (($OUT[1]==FALSE) and (o1f==false))THEN
    o1f=true
    CWRITE(HANDLE,SW_T,MW_T,"%s","A")
    OFFSET=0
    CREAD(HANDLE,SR_T,MR_T,TIMEOUT,OFFSET ,"%s", EMPTY)
    ENDIF
    endloop
  • panic mode
    1,296
    13,136
    • July 1, 2024 at 8:47 PM
    • #16
    and...? what about it?
    it is incomplete so one cannot even tell if it would compile.
    and what is the problem? keep in mind not everyone has access to a robot, certainly one of that vintage. so whatever you do, or ask, better support it with your observations... state behavior, messages, data transmitted etc.
    did you read the manuals? according to CWRITE manual for KSS5.5 it is missing $CMD but manual for 4.1 does not use it. so what is your KSS version? also your o1f flag is never reset, so will let your IF statement only be processed once.
    but this is just program. are you sure that wiring and port configuration is correct? what is sending data that you are receiving? are you sure the port settings are the same? do you have a loopback adapter?
    if you do not have other device to talk to, it is practical to use loopback. basically it is just a DB9F connector with pins 2 and 3 connected to each other. the nice thing about this is that port settings are almost irrelevant, no external device to setup, and whatever you send comes back. so you can do the development in stages, have your code write something and make sure that this part compiles. then you can add code to read what you just sent... and program examples from manual should be piece of cake to try out.
    if talking to external device, you need proper cable. type of cable depends on type of device (DCE/DTE). you can have program that compiles and runs but if wiring is incorrect, this will go nowhere...
  • MOM
    176
    7
    1,424
    • July 1, 2024 at 10:09 PM
    • #17
    Quote from MOM
    Using CWRITE you do not need to set an offset - my fault.
    But you must check the return code
    CREAD : SR_T
    CWRITE: SW_T
    I cannot find them in your code snippet (post #15)
  • MOM
    176
    7
    1,424
    • July 1, 2024 at 10:15 PM
    • #18
    Hint:
    search for the document "CREAD CWRITE R4.1 07.02.00 en"
Similar Threads
  • Cell with a large number of P Variables - YRC1000
    • Woebot
    • April 18, 2022 at 8:40 AM
    • Yaskawa Motoman Robot Forum
  • Message Communcation with PROFINET (or Ethernet/IP)?
    • paranoidandroid
    • August 30, 2022 at 5:56 PM
  • What is the correct way to get coordinates from external device ?
    • Zadok the priest
    • April 21, 2022 at 8:10 AM
    • KUKA Robot Forum
  • Commanding LR-Mate with python scripts
    • mahboobelahi93
    • September 15, 2021 at 10:09 AM
    • Fanuc Robot Forum
  • Kuka robot project and difficulties
    • Oatesy
    • December 17, 2020 at 5:59 AM
    • KUKA Robot Forum
  • Questions about AS features by KRL programmer
    • Mentat
    • November 25, 2020 at 9:24 PM
    • Kawasaki Robot Forum
  • programming strategies transmitting variables
    • JuEdir
    • November 27, 2020 at 8:05 AM
    • KUKA Robot Forum
  • Arrays of Points
    • Eragorn
    • October 14, 2020 at 7:25 PM
  • serial
