Write value to FLG in KAREL
  • MrChong
  • June 13, 2024 at 9:43 PM
  • MrChong
    5
    Hello everyone,
    We are currently developing a Fanuc Plugin in KAREL and we are having some issue to write value to FLG i/o.
    In the simulator, the writing process works perfectly, but when it's time to push the plugin into a CRX (used with the tablet), writing into flags doesn't seem to work. In parallel, we also write into Numeric_Register, and the process is working. I am confused at the moment.
    We verified if any background routine overwrite the flag (negative), we manually set the FLG to ON and it stays ON.
    Here's the include:
    %ENVIRONMENT TLIF
    %ENVIRONMENT PC
    %ENVIRONMENT IOSETUP
    %ENVIRONMENT REGOPE
    %INCLUDE etdccopt
    %INCLUDE klevccdf
    Here's how I set the flag:
    Stop_Rdy = FLG[114]
    flag_number = 101
    flag_value = TRUE
    IF Stop_Rdy = TRUE THEN
    FLG[flag_number] = flag_value
    ENDIF
    What am I missing to make it work on a real controller?
  • Lemster68 June 13, 2024 at 9:54 PM
    Approved the thread.
  • RobcadSim
    10
    63
    • June 18, 2024 at 8:17 AM
    Doesn't look like anything wrong, try it another way.
    We like to :
    SET_PORT_VAL : set port value,u can use this to set flag on / off (1/0).
    SET_PORT_CMT: set port comment.
    the pic , FLAG[261] will be on,when run the pc, and its comment will be 'TIP CHANGE REQ'
    Nice day~!
  • MrChong
    5
    • June 18, 2024 at 6:06 PM
    Thank you for the reply. May be it was our fault with the verification, but for now it's working fine. I used the variable in a "variable karel program" and it seems to be our problem.
    So far so good, everything working now
  • Karel programming
  • FLAG
