Byte Swap Not Working in WoV 6.0
  • Ardeshir Talaei
  • June 12, 2024 at 5:36 PM
  • Ardeshir Talaei
    5
    I am trying to communicate a 16-bit UInt from Robot to a Siemens S7-1200 but I cannot figure out why the byte swap is not working.
    KRC4 KSS 8.6 + WoV 6.0
    Here are screenshots for the IO mapping and byte swapping in WoV:
    The signal is defined in $config.dat:
    ; Userdefined Variables
    SIGNAL MTEC_SET_FREQ $OUT[17] TO $OUT[32]
    SIGNAL MTEC_RUN_PUMP $OUT[33]
    And set it to 1 in the SmartPad, but in TIAPortal, I receive it as 256. There is no byte swapping in TIAPortal and I also checked the signal bit by bit. The byte order is not changing, no matter if I configure the byte swap in WoV or not. It's always LSBF!
    256 on the robot is received as 1 in TIAPortal, so I'm sure the addresses are not shifted.
    Am I missing something?
    Any help would be highly appreciated. :tired_face:
    Many thanks in advance.
  • panic mode
    1,295
    13,130
    • June 12, 2024 at 9:41 PM
    what are your steps? what exactly did you do after swapping bytes in WorkVisual? did you deploy the project back to robot? did you activate it?
  • Ardeshir Talaei
    5
    • June 13, 2024 at 10:32 AM
    I just follow the normal procedure . . . Deploy (F6) and it automatically activates the project. Should I do anything more?
    Also tried deleting all the projects on the robot and deploying it as a new project. No luck!
    I don't need to set it as the base project, do I?
  • hermann
    411
    2,621
    • June 13, 2024 at 1:18 PM
    No, your procedure is correct.
  • panic mode
    1,295
    13,130
    • June 13, 2024 at 3:31 PM
    yup... if only change is IO setup, that will be it. it may be an issue with WoV. what version you have there? and this is not pretty but it only need to be done once and should solve it no matter what:
  • panic mode
    1,295
    13,130
    • June 13, 2024 at 3:40 PM
    or you can group them as bytes, just so that they stand out. this should make it obvious for anyone doing any future modifications.
  • Ardeshir Talaei
    5
    • June 13, 2024 at 7:08 PM
    Thank you for your suggestion. The thing is that I asked about one signal, but I actually need many. I prefer to swap the bytes in the PLC program if it comes to that.
    I'm using WorkVisual 6.0.29_Build3018
    I just realized that after I deploy the project, if I compare the local project with the controller's active project, there are some differences left. It includes Bus Config for EMD, System Machine Data, and 8 files (screenshot). Is it normal? Could it be the problem?
  • panic mode
    1,295
    13,130
    • June 13, 2024 at 7:46 PM
    use the Compare files feature (lowe left corner)
  • Hes
    42
    243
    • June 14, 2024 at 5:04 PM
    Id say that bits need to be grouped (in the view where you swap them) for the swap to do anything. Otherwise it looks ok.
  • Siemens 1200
  • byte swap
  • wov 6.0
  • Siemens PLC
