  4. ABB Robot Forum
New system does not load
  • Thalespereira
  • June 12, 2024 at 12:18 PM
  • Thalespereira
    Hello everyone, I have the following problem on robots model irc5. I'm creating rw5 systems from existing robot backups and trying to install on a flash compact that I applied x-start. However, when installing the new system, when restarting the controller loads the new system's loading screen, from that moment it hangs in the middle of loading and restarts to the bios without any system installed. I also noticed that after installing the system, none appear in the installed systems tab. I noticed that the rw of the backup being created was 5.13.10 and my rw was 5.15. I then tried to create the system from rw 5.13.30 but the same thing happened.
  • MOM June 12, 2024 at 2:05 PM
    Approved the thread.
  • Lemster68
    295
    2,454
    Blog Articles
    7
    • June 12, 2024 at 4:24 PM
    What do you mean by installing on a compact flash card? Did you remove it from the robot? You should be connecting to the robot with robotstudio or creating a usb install.
  • Thalespereira
    • June 12, 2024 at 9:42 PM
    The robot's compact flash, I applied c-start to delete the entire system from the robot's memory to install another
    Lemster68
  • saberlars
    Robot, beyond Human..
    22
    223
    • June 13, 2024 at 5:27 PM
    Have you tried uploading an image file to the controller using System Builder?
    ABB, FANUC, Hyundai, Kawasaki
  • Thalespereira
    • June 15, 2024 at 7:03 AM
    Quote from saberlars
    Yes, that's what I did, according to the ABB manual, following the entire procedure. I tried to download the system builder and boot media with a pendrive and the same thing happens on both.
  • SomeTekk
    16
    201
    • June 18, 2024 at 10:21 AM
    Canyou X-Start the IRC5 and see if there are already systems on the Compact Flash?
    Also, if you are able to get to the Boot Application you could set an IP up for the LAN port and ftp to the CF and see if there is a problem.
    Finally, if the CF is a clone, good luck. VxWorks (the control kernel) is very difficult to get working as intended.
  • FSD-Robotics-Radwell
    10
    • June 18, 2024 at 4:09 PM
    You likely have a corrupted flash card. If you need spare cards we sell the 1 Gig models. Our robotics tech support can also preload your system on the flash card for you if needed as well if you can send us a backup or the keystrings.
    Robot Tech Support Team
    FSD Robotics - A Radwell Company
    Radwell International
    email: fsdrobotics@radwell.com
    http://www.factorysurplusdirect.com
    http://www.radwell.com
  • Black
    124
    • June 23, 2024 at 8:24 PM
    disassemble the CF card, mount it with an adapter to the computer, see if you have a system,
    I send you an irc5 ghost, BUY a NEW cf card and try it
    DOM_irc5Ghost
    3 files sent via WeTransfer, the simplest way to send your files around the world
    we.tl
  • Thalespereira
    • June 29, 2024 at 11:44 PM
    Quote from Black
    https://we.tl/t-iErG07SmHx
    Hello thank you so much. Can you give me more details on how to use the files? Should I just copy and paste into CF? Thank you again
  • Black
    124
    • July 1, 2024 at 10:58 AM
    tutorial Ghost ,its the first i found on youTube
    ghost is a program that copies and writes partitions on hdd.
    Put the NEW CF Card in the USB adapter and write the partition with the Ghost program.
    Now you will have ONE bootable CF card for Robot Irc5.
    The card will NOT contain any System, you will have to install it, thus eliminating the possibility that your Cf Card is corrupted
    Irc5_Ghost.zip
    BUY A NEW CARD
    Edited once, last by Black (July 1, 2024 at 11:37 AM).
Similar Threads
  • D3x Controller basic configuration setup for repurpose
    • ArcadeMachinist
    • May 5, 2024 at 9:20 PM
    • Kawasaki Robot Forum
  • I feel like it and I'm bored, my new project: M2000 and 7+8 axis
    • robiman
    • January 28, 2024 at 8:16 PM
    • ABB Robot Forum
  • Automating program upload to KRC4 via Ethernet
    • nicok
    • February 23, 2023 at 5:46 PM
    • KUKA Robot Forum
  • Can I load .as file to the controller in K-Roset?
    • RD24
    • November 30, 2022 at 3:06 AM
  • Multiple instances of same OfficeLite?
    • bootsch
    • July 25, 2022 at 5:39 PM
    • KUKA Robot Forum
  • I need config for abb irb 6400/f/2.4-150e s4
    • wowa_wa
    • February 10, 2022 at 8:42 PM
    • ABB Robot Forum
  • EKI - PTP commands executing too slow
    • Ravnicas
    • January 10, 2022 at 10:46 AM
    • KUKA Robot Forum
  • Motion as IN OUT parameter
    • pavlan1
    • March 26, 2021 at 8:22 AM
    • KUKA Robot Forum
  • Approximated points
    • SBDP_4.0
    • May 13, 2020 at 6:04 PM
    • KUKA Robot Forum
  • Installing KUKA.Ethernet IP 1.1 Scanner/Adapter
    • mcasa0802
    • May 14, 2020 at 1:29 AM
    • KUKA Robot Forum
