I am new to the robotics like FANUC, UR. So, for a recent project I am using a FANUC CRX model robot. In the robot as far as i know (I am a beginner) i could not find an air supply port. So I have to use it separately. Can anyone help me to get an idea how to plug air supply unit to the robot? I want to use the air supply unit to open and close the air supply for air grippers attached to the robot arm.
Pneumatic supply to the FANUC CRX
Tech -
June 12, 2024 at 6:48 AM -
Roland Keller
June 12, 2024 at 7:36 AM Approved the thread. -
Collaborative robots generally use electric grippers because they do not have an internal air hose.
CRX DevicesFANUC Approved CRX Collaborative Robot EOAT, Peripheral Devices, and Device Plug-ins are quick and easy with the CRX Cobot.crx.fanucamerica.comcheck out Devices.
For the 25kg model, internal air hose is standard.
For 10kg and 20kg it's an option. Not sure if possible to retrofit it.
For the 5kg model there's no room for air hose.
Normally you just route the air hose along the robot arm, either with zip-ties or using some robot hose soulition (see for instance Leoni)
