Hi all
I want to connect KMR 200 iiwa 14 omnimove with ROS2 using FRI. I used example from this link: Verify Connection to the Robot — LBR-Stack 1.4.3 documentation.
However, whenever tried to run LBRServer application, nothing happens. I used the enabling switch and run the java application. However, I can move the robot base and arm manually with the Kuka controller.
There is a warning from the safety controller. Can anyone help me to solve the warning.
Error message:
- Position sensor not mastered (K2:A1, A2, A3, A4)
- Position sensor not referenced (K1: A1, A2, A3, A4, A5, A6, A7)
- Error reading offsets of mastering marks for positioning referencing.
- Axis without safe torque sensor (K2:A1, A2, A3, A4)
- There are deactivated rows in PSM configuration.
