Fanuc robot and Allen Bradly Ethernet Ip Communication
  • Ryuk7
  • May 30, 2024 at 9:16 AM
  • Ryuk7
    36
    request your assistance with an issue we are experiencing with our FANUC robot (R30iB plus controller) and Allen Bradley PLC (L30ERM). We are attempting to establish communication between these devices via Ethernet IP.
    We have successfully set up the network and the robot is pinging with the PLC. However, on the communication page, it does not indicate that it is running. This is our first time attempting Ethernet IP communication with the robot, so we are unsure of the next steps to resolve this issue.
    Here are the steps we have taken so far:
    Enabled UI signals
    Added the PLC in the TCP/IP settings under Host Comm
    Despite these steps, we are still unable to establish a successful connection. Any guidance or information you could provide would be greatly appreciated
    I'm No One, I Don't Want To Be Anyone.
  • hermann
    407
    2,615
    • May 30, 2024 at 9:20 AM
    Did you search the forum? There already exist many threads about eternet/ip and plc. Sometimes with Roboguide, but setup procedure is the same.
  • Ryuk7
    36
    • May 30, 2024 at 9:28 AM
    Quote from hermann
    Yes, I have done all basic settings , but i don't have that much idea at PLC end may be I'm missing something at PLC end . Robot and PLC are pinging but connection doesn't goes in running state
  • Nation
    Typical Robot Error
    547
    1,925
    • May 30, 2024 at 12:12 PM
    Does the robot have the ethernet/IP adapter or scanner option installed?
    If so, have you configured the connection on the robot side, and enabled it? That is under the ethernet/IP area in the IO menu. Rember the robot configured is in words, and the PLC side is in ints (or bytes, I can't remember off the top of my head, whatever it is, the lengths won't match).
    On the PLC side, did you install the correct Fanuc EDS file (this differs based on controller generation, so you have to use the right one), or are you using a genetic ethernet module?
    Under the File menu, you can have the robot write out the comm configuration files.
  • Sergei Troizky
    70
    658
    • May 30, 2024 at 6:52 PM
    Quote from Ryuk7
    What is "the communication page"?
    Enabled UI signals
    This has nothing with Ethernet/IP.
    Do you have Ethernet/IP option installed?
    Scanner or adapter?
  • Ryuk7
    36
    • June 3, 2024 at 8:54 AM
    Quote from Sergei Troizky
    Scanner or adapter?
    I havr both the options , for robot side I'm keeping it ADP
  • Ryuk7
    36
    • June 3, 2024 at 9:05 AM
    Quote from Nation
    Yes, I have taken EDS file from controller , I have configured connection , in host communication setting it ping as with the plc ip address and on IO > Ethernet ip > PLC shows online not running while trying to ping it on that page it shows invalid alarm
  • Ryuk7
    36
    • June 3, 2024 at 9:07 AM
    Quote from Ryuk7
    and we get PRIO 230 Ethernet ip adapter error
    and PRIO231 Ethernet ip adapter idle warnings
  • Nation
    Typical Robot Error
    547
    1,925
    • June 3, 2024 at 3:32 PM
    Can you post a robot backup, and a PLC file? Or directly message them to me?
  • Ryuk7
    36
    • June 10, 2024 at 8:54 AM
    Quote
    Problem solved - The problem was with the IO assignment we had assigned port 1 to weld equipment but on bord it was connected to port 2 . we assigned plc to port one and connected the ethernet to port 1 it worked
  • Allen Bradley
  • R30-iB plus
