Fanuc User levels question
  • Fanburg
  • May 29, 2024 at 6:15 PM
  • Fanburg
    I am setting up fanuc user levels, is there a way to use PLC data to enter the password or user data into the fanuc? I am controlling the robot using ethernet IP from an AB compactlogic PLC, which already is using RFID for login/user tracking of HMI access levels, and looking to see if there is any method I can use the PLC to login to the robot so all user access is controlled through 1 point of access.
    My thought was to run BKG logic that examines input data from the PLC and changes user access levels on the robot, but cannot see a way to change user levels within logic.
  • 95devils May 29, 2024 at 6:20 PM
    Approved the thread.
  • R47
    110
    • May 31, 2024 at 8:10 AM
    I created something like this with Karel. Its possible.. if you need help just let me know:thumbs_up:
  • Beek
    36
    • May 31, 2024 at 7:27 PM
    Quote from R47
    Are you able to login to different levels from the PLC or just the admin? I'm currently using the autologin_3 to login as admin but if its possible to have operator and techs also login to their levels that would be better as I could eliminate the USB drives for login.
  • R47
    110
    • June 3, 2024 at 4:21 PM
    You can login in different levels
  • Bwille
    8
    • June 10, 2024 at 3:37 PM
    Quote from R47
    R47, i sent you a message. im curious about doing this as well.
  • ssaul
    8
    52
    • June 10, 2024 at 5:50 PM
    Hello guys, I would like to do the same with my robots, can you give me the Karel program or what you are using to be able to implement it?
    thank you
  • akay98
    13
    • May 7, 2025 at 2:14 PM
    Hi Guys,
    I want to do the same thing. Can you please share me also the KAREL program. It would be a great help.
    Thank alot
  • RoboHorst
    • June 3, 2025 at 9:49 AM
    Quote from R47
    Need to do the same. Your KAREL Program would be of great help.
    Big thanks in advance.
  • R47
    110
    • June 4, 2025 at 4:52 AM
    hello,
    i atached the karel file.
    How to use it:
    1. select it in Macro table and run it there with DI[99] (DI[99] needs to be ON as long as the user is logged In)
    2. send DI[100] for level 1, DI[101] for level 2, DI[102] for level 3, DI[103] for level 4 or DI[104] for level 8 (i think admin is level 8 if i remember correct)
    3. turn DI[99] off to logg out
    the .pc file is in version 8.3.. if you need in another version please let me know or if you need other Inputs
    i also attached one usefull karel to read the password from different users.. sometimes its usefull if the user forgets his password. just select and run.. enter the listnumber where the user is located or enter 999 to show all users.
    Files
    password.zip 2.77 kB – 16 Downloads
    Edited 2 times, last by R47 (June 4, 2025 at 5:09 AM).
