Manipulator : BXP210L-A001
Controller : F02 (Application - Servo welding gun)
.*=== AS GROUP === : ASF_02010000V 2023/12/11 13:50
.*USER IF AS : UASF02010000V 2023/12/11 13:50
.*USER IF TP : UTPF02010000V 2023/12/11 13:49
.*ARM CONTROL AS : AASF02010000V 2023/12/11 13:50
.*USER IF AS MESSAGE FILE : MASF020000VEN 2023/12/11 13:45
.*USER IF TP MESSAGE FILE : MTPF020000VEN 2023/12/11 13:45
.*ARM DATA FILE : ARMF02010000V 2023/12/11 13:49
.*KERNEL : _KNL303600000 2022/09/28
.*DRIVER : _DRV304300001 2022/06/28
.*RFS : _RFS301000501 2021/03/03
.*=== SERVO GROUP === : SVF_01000001Y 2023/01/23 12:40
.*ARM CONTROL SERVO : SVSF01000001Y 2023/01/23 12:39
.*SRV DATA FILE : SVPF01000001Y 2023/01/23 12:40
.*ARM CONTROL SERVO FPGA : SVFF01000000C 2022/11/09 09:15
.*Cpu board type : 2AA
.*Controller ID : 002
.*CFast Serial No. : AO2230731244001493
.*CFast Model : SQF-S10U1-16G-BKI
.*FB1 Port : Anybus-CC Slot1 CC-Link 1.03.1
.SYSDATA
REG_POINT 0
REG_ANGLE 0
BASE 0.000 0.000 0.000 0.000 0.000 0.000
ENV_DATA 300 0 5 0 0 0 0 0 0 0
ENV2_DATA 0 0 0 0 0 0 0 0 0 0
CHECK_SPEC 1 1 1 1 1 1 1 1 0
CHECK_SPEC_JUMP 1
DEFSIG_I EXT_MTRON OFF 0
DEFSIG_I EXT_ERR_RESET OFF 0
DEFSIG_I EXT_CYC_START OFF 0
DEFSIG_I EXT_PROGRM_RST OFF 0
DEFSIG_I EXT_JUMP OFF
This is a partial information on the controller of the F02 model currently in use.
The CHECK_SPEC11 parameter exists in the E-type controller for general handling, but the new F02 controller does not have this parameter.
I would like to use the "CmdLine-Run" method like other maker robots, but how can I do this?
The following picture shows the option specifications confirmed in K-Roset.
.SYSDATA
REG_POINT 0
REG_ANGLE 0
ENV_DATA 0 0 1 0 0 0 0 0 0 0
CHECK_SPEC 1 1 1 1 1 1 0 1 0
CHECK_SPEC_JUMP 1
CHECK_SPEC11 ON
The [CHECK_SPEC11] parameter is included even though the selected software version in the simulator is lower.
I thought it would be supported since the software version of the F02 controller recently received is higher,
but I couldn't find it in the UI.
I tried uploading only a part of the parameters of the corresponding SYSDATA, but it was not activated.
