When to use position variable
  • George32
  • May 25, 2024 at 9:05 AM
  • George32
    7
    Hi folks,
    I may have a silly question, but I couldn't find the answer for myself.
    I currently have a year of beginner experience in programming a robot.
    With this beginner experience, I have managed to automate some complex operations. However, I find that I go through all the available position variable rather quickly.
    Hence my question which is: when is it convenient to use position variable and when is it wise to just use the insert + enter (Movl/Movj)?
    I look forward to your responses
  • 95devils
    235
    8
    1,949
    • May 25, 2024 at 12:11 PM
    I only use P-variables for absolute moves when I am calculating positions, like palletizing.
  • TSGIR
    81
    715
    • May 27, 2024 at 11:21 PM
    The insert + enter is a quick way to teach the path special in the welding application.
    The position variable use usually to save position and use it in calculations, or you have a camera and need data send to robot and save in a position variable.
    Depends on the your application, you can decide which method needs to use but insert+enter is normal method.
  • WattUp
    7
    96
    • May 28, 2024 at 2:38 PM
    80-90% of all my robots are programed with standard (insert+enter) move types.
    We use PVAR on model specific positions where a common job is running for every model, but some positions are exclusive and we call a PVAR with a integer pointer.
  • doomedblue
    38
    • May 28, 2024 at 11:51 PM
    i weld ibeams and i use a pvar for my safe position when moving from side to side and the rest of the job is the (insert+enter) moves
  • Woebot
    5
    24
    • June 4, 2024 at 8:59 AM
    I do mostly press line transfer/machine tending jobs or pick and place assembly type jobs and use pvars almost exclusively because my cells usually need less than 100 positions total and the pvars are easy to read, edit and name. Not saying that’s the best way, just how the company I work at does it.
  • Woebot
    5
    24
    • June 5, 2024 at 3:21 AM
    Quote from George32
    ... I find that I go through all the available position variable rather quickly.
    Also If you are running out of stock pvars and you have a YRC1000 controller you may want to look into expanding the variable memory allocation. You can expand the global pvars up to 1600 variables. I had some help with this in a thread a while ago:
    Cell with a large number of P Variables - YRC1000
    How to do it is described in the YRC1000 instruction manual under variable allocation
Similar Threads
  • Cell with a large number of P Variables - YRC1000
    • Woebot
    • April 18, 2022 at 8:40 AM
    • Yaskawa Motoman Robot Forum
  • Learning Motoman
    • panic mode
    • September 7, 2023 at 3:21 PM
  • Programs becoming corrupted after transferring from USB
    • ClassyBanana
    • November 29, 2022 at 7:48 PM
  • Reverse-engineering AS programs
    • SkyeFire
    • May 31, 2022 at 9:35 PM
    • Kawasaki Robot Forum
  • CHECK_EPOS built-in, finding the right parameters -how to get the UTOOL and UFRAME in KAREL as POSITION data type
    • FLrobotics
    • November 18, 2020 at 3:33 PM
    • Fanuc Robot Forum
  • Motoman MRC alarm 5750 undefined position variable
    • Czirjak Cristian
    • February 16, 2019 at 4:45 PM
  • Comment utiliser les repères utilisateur sur Motosim
    • Basteak
    • August 6, 2020 at 12:13 PM
