Fanuc robot doesn't move at the programmed speed
  • Chuy_Buttowsky
  • May 24, 2024 at 7:17 PM
  • Chuy_Buttowsky
    First of all, hello to everyone :hi-bye:.
    I have a fanuc cobot (CR-15iA) with the R30-iB plus controller. It is a vision application, and the problem I have is that when I have movements that approach the limits of the axes, the speed drops :wallbash:. As if the cobot was being protected, but being a vision application with a profile sensor it cannot have those speed drops. The measurement movements are at 600 mm/s speed.
    The question is if exists some DCS parameter or varible that is protecting the robot? Or something that ensures it runs at the programmed speed. :gaah:
    Thanks.
    Edited 2 times, last by Chuy_Buttowsky (May 25, 2024 at 12:14 AM).
  • MOM May 24, 2024 at 7:38 PM
    Approved the thread.
  • Fubini May 24, 2024 at 8:08 PM
    Moved the thread from forum General Discussion of Industrial Robots Only to forum Fanuc Robot Forum.
    SkyeFire
    1,061
    9,463
    • May 24, 2024 at 9:37 PM
    Quote from Chuy_Buttowsky
    What type of motion? Linear or Joint?
    Which limits? Certain axis combinations simply cannot move quickly, especially for L moves.
    What is your DCS setup? Do you have safety zones configured? Have you tried testing with DCS bypassed?
  • Chuy_Buttowsky
    • May 24, 2024 at 10:28 PM
    The program has joint and linear moves, but I only cares about the linear moves.
    Mainly the limits of the axis 2 & 3.
    No, I don't have safety zones yet. Only I have the payload and that's all.
    How can I bypass the DCS?
  • HawkME
    570
    3,270
    • May 26, 2024 at 3:15 PM
    Is it approaching a Fine moment? Are you sure it's not the normal decel as it approaches the point?
  • Chuy_Buttowsky
    • May 27, 2024 at 6:57 PM
    Yes, I'm sure, because I have other movements that don't approaches to the limits of axis 2 & 3. And these movements are closer to the programmed speed. And are fine movements too.
  • HawkME
    570
    3,270
    • May 28, 2024 at 3:35 AM
    It may be an axis speed limit issue. Usually there woul be a warning that appears if that is the case.
    Also it is a collaborative robot. It may need to reduce speed when the reach is extended in order to maintain safe force limiting.
    SkyeFire
    1,061
    9,463
    • May 28, 2024 at 4:43 PM
    Is the robot approaching a pose where the elbow would be nearly straight?
    Quote from HawkME
    That's a potential factor. For a Cobot, that elbow is a potential risk -- there are certain poses where small motions of the TCP can translate into large motions of the elbow, and the elbow's speed has to be safety limited just as much as the wrist speed, otherwise it could club someone in the head with dangerous force.
  • Velocity error
  • Cobot
Users Viewing This Thread
  • 1 Guest
