a query about the Tool Center Point (TCP) moving in an unexpected direction. We were advised by Fanuc to use a trial and error method to align the TCP with the robot by adjusting the motor direction and other settings. However, we are having trouble aligning the TCP as per our Real world cell.
We have generated this cell from the backup of our Real world robot cell, but we are encountering issues with the movement of the 8th and 9th axes.
When we align the TCP in the RoboGuide software with the robot, the robot jogging gets inverted.
For instance, for the 9th axis at the physical cell, when pressing the Z- key, the robot jogs in the left direction from the point of home.
But in RoboGuide, when jogging the 9th axis by the Z- key, the 9th axis moves to the right direction.
if we adjusted settings as per real world cell the TCP moves at wrong direction from robot. The same scenario happens with the 8th axis.
We have not found any solution in the help menu or any documentation regarding this particular concept.
We are having trouble calibrating the actual cell with the RoboGuide cell due to this issue.
