Bad tcp
  • MIJ
  • May 22, 2024 at 11:37 PM
  • MIJ
    13
    I have a KR8 kuka robot. I taught a tcp and got the error down to 0.39, however when I tested the tcp I found that it's way off. Is this normal? Does this happen to anyone else?
  • Fubini
    278
    1,889
    • May 23, 2024 at 12:26 AM
    How did you test it? By any chance is your robot equipped with the absolute accuracy package? If you tested while jogging try again with a program. While jogging absolute accuracy model is turned off.
    Fubini
  • panic mode
    1,280
    13,086
    • May 23, 2024 at 12:33 AM
    things can also get really weird when wrong MADA is used or if robot is not mastered correctly or if tool is not mounted correctly (without dowel pin) or if tool is flexible or if reference point moved during measurement...
  • MIJ
    13
    • May 23, 2024 at 12:35 AM
    I am not very sure about the absolute accuracy package. I will check and yes i just checked by rolling the torch around in A,B and C. So how else can I test the TCP? Do I have to be in a program and then try jogging it, is that what u mean?
  • MIJ
    13
    • May 23, 2024 at 12:38 AM
    If nothing works maybe I will try to do that option which enables me to check my mastering.
  • hermann
    407
    2,612
    • May 23, 2024 at 8:20 AM
    Quote from MIJ
    .. when I tested the tcp I found that it's way off...
    What does this mean? Quantify 'way off'
  • MIJ
    13
    • May 23, 2024 at 2:47 PM
    Means when I rotate the tool around A,B, C it's going all over the place instead of holding on to the center.
  • panic mode
    1,280
    13,086
    • May 23, 2024 at 2:54 PM
    you still did not answer the question. "way off" and "all over the place" are not a number.
    quantify it means measure it, provide a value... 1mm, 10mm, 100mm, 1km...
    if the wobble is small (~1-3mm) it may be normal for the robot and chosen TCP.
    if the wobble is larger (~ 3-10mm) it is likely that reference point moved or tool shifted.
    if the wobble is even larger it is likely that problem is with mastering or MADA or belts slipping etc.
    in fact you did not provide any data. what is the measured TCP you got? is it far from flange?
  • SkyeFire
    1,052
    9,429
    • May 23, 2024 at 2:57 PM
    Quote from MIJ
    Yes, but how much? How many mm of displacement per degree of rotation? On which axes? Quantifying the characteristics of the error is important. Orientation changes are the worst case for robot accuracy -- even a perfect TCP can easily drift 1mm over 90deg of rotation.
    Usually, if the MADA are incorrect, achieving a low error on the TCP 3-point process isn't possible. Incorrect LOAD_DATA could be a potential cause of what you're seeing. Activating the wrong Tool could be another. As has been stated upthread, the best test is to create a test program that touches the TCP to a reference point at multiple rotations, rather than jogging the robot manually.
Similar Threads
  • TCP error
    • silvanofilho
    • April 19, 2021 at 9:23 PM
    • KUKA Robot Forum
  • WorkVisual cannot detect KRC, and some other weird networking stuff
    • magyaricsn
    • August 14, 2023 at 5:08 PM
    • KUKA Robot Forum
  • Standard programmation VW with fanuc robot
    • AlexandreM
    • June 2, 2023 at 4:40 PM
    • Fanuc Robot Forum
  • Problem with KUKA base calibration
    • dezile
    • April 11, 2023 at 6:35 AM
    • KUKA Robot Forum
  • RoboGuide: When the base of a Fanuc robot is rotated, the UserFrame rotates with it... how can I avoid that?
    • EBri
    • February 16, 2022 at 10:07 PM
    • Fanuc Robot Forum
  • Calculating Dispense Tip with 2 intersecting lasers
    • jreneberg
    • February 1, 2022 at 10:36 PM
    • General Discussion of Industrial Robots Only
  • Constrain TCP in B and C movement due to singularities at axis 4. Tool is not allowed to be tilted in axis B and C doing movement, but direct SLIN movement causes singularities.
    • ChristianLiinHansen
    • January 17, 2022 at 11:36 AM
    • KUKA Robot Forum
  • Down the rabbit hole...Who wants to join in the fun?
    • Elderwild
    • November 30, 2021 at 8:25 PM
    • ABB Robot Forum
  • How do you calculate tcp?
    • moln4r
    • February 16, 2021 at 7:28 PM
    • Fanuc Robot Forum
  • Difficulty calibrating laser touch sense
    • mbull
    • October 23, 2020 at 9:42 PM
    • Fanuc Robot Forum
  • tcp variation
