KRC2 from safe robot to standard
  • robot-cnc
  • May 22, 2024 at 7:05 PM
  • robot-cnc
    431
    Hi
    I want to change on a safe robot kuka KR 60 KRC2 year 2012, with kss 5.5.16 the safe RDW with a new Standard RDW 2. I understood I have to do an A1 jumper plug in on ESC CI3 Tech from controller.
    A1/X23 is the connection that link ESC board with safe RDW through cable X21.1 to X41.
    There is any wiring diagram for A1/X23 ?
    Is that enough to change safe robot to standard?
    Images
      • 294.01 kB
      • 1,920 × 865
      • 20
      • 245.39 kB
      • 1,920 × 865
      • 14
  • robot-cnc
    431
    • May 22, 2024 at 8:13 PM
    Does it make sense this wiring on A1/X23 ?
    Images
      • 193.05 kB
      • 780 × 834
      • 46
  • panic mode
    1,278
    13,076
    • May 22, 2024 at 8:31 PM
    what exactly you have in mind? what are you jumpering? pretty sure that shorting TA outputs to GND is a bad idea.
    if you remove SafeRDC, the connections and software for safe robot need to be gone as well. so i would start by duplicating HDD and finding schematics of a system that uses same type of safety board but without safe robot option.
  • robot-cnc
    431
    • May 22, 2024 at 9:04 PM
    I am thinking to use a regular RDW 2 , to jumper what is needed on ESC board ....remove kss 5.5.16 and install 5.6....with no Safe Operation.
    Could CI3 Tech act as a CI3 standard?
  • panic mode
    1,278
    13,076
    • May 22, 2024 at 9:06 PM
    yes tech boards (CI and MFC) can be used in place of standard boards
  • sjx
    25
    96
    • May 22, 2024 at 9:52 PM
    Quote from robot-cnc
  • robot-cnc
    431
    • May 23, 2024 at 8:45 AM
    Quote from sjx
    Thank you for diagram.
    SR1A and SR1B are ENA_A_24V and ENA_B_24V(safe output) or COROB_EN_A_24V and COROB_EN_B_24V(safe input) ?
    Images
      • 186.71 kB
      • 780 × 834
      • 24
  • jesusvaricap
    259
    • July 23, 2024 at 6:16 AM
    Thread
    Errors Adding External Axis to 5.5.12
    Hello ,
    Im trying to add an external axis to the robot KR16_2 C2 # article 11010711 with cabinet (V)KRC2 ed05 # article 11010711 KSS 5.5.12
    With motor # article 69-225-463 and KSD1-32 # article 00-122-286
    in the past i configured the same motor and KSD32 with KSS 5.2.14 KR2210L150S2000 with no problems
    attached madas
    Now , i configure my MADA for 5.5.12 with the data before used on KSS5.2.14 and appears errors:
    436 short circuit braking request by RDC1
    114 difference between XML /RDC…
    jesusvaricap
    December 21, 2022 at 4:31 AM
    Check this older own post
    It's about saferobot
Similar Threads
  • krc2ed05 saferobot
    • javaman
    • February 6, 2024 at 3:00 AM
    • KUKA Robot Forum
  • esc-ci to esc-ci3 conversion
    • javaman
    • September 25, 2023 at 12:29 PM
    • KUKA Robot Forum
  • KR C2 Ed 05: RDW configuration error and RCDSafe disable
    • jsalonso
    • December 13, 2023 at 11:32 AM
    • KUKA Robot Forum
  • USED KRC2 ed05- Cannot create New program or jog the robot at all
    • RoboIvan
    • January 16, 2021 at 9:50 PM
    • KUKA Robot Forum
  • "Safe device communication error KUKA Servo Pack 40A (KSP) 1" error message
    • Wall-E
    • January 7, 2022 at 10:21 PM
    • KUKA Robot Forum
  • KRC2 ED05 X11 Connector Unexpected Behavior
    • robonovak
    • August 17, 2021 at 6:30 PM
    • KUKA Robot Forum
  • How to turn off safety output KUKA
    • Alex_Moser564
    • January 31, 2018 at 4:43 PM
    • KUKA Robot Forum
  • krc2 ed 05 MFC3 - tech alternative or bypass
    • vvelikov
    • May 29, 2020 at 5:21 PM
    • KUKA Robot Forum
  • RDW
