  4. ABB Robot Forum
ABB IRB 140 Digital Output Signals
  • Ali Kavian
  • May 20, 2024 at 2:01 PM
  • Ali Kavian
    I am new to robotics and am trying to use digital output signals in the ABB IRB 140. I have connected the DSQC 328 to the controller, and both the MS and NS lights are lit. However, I am having trouble with the wiring. I don’t actually know where to connect the GROUND wire. I think it might be pin 9, but I’m afraid of damaging the robot. Can somebody help me with the wiring? Are there any important safety issues I need to consider?
  • SkyeFire May 20, 2024 at 2:35 PM
    Approved the thread.
  • Lemster68
    295
    2,454
    Blog Articles
    7
    • May 20, 2024 at 3:34 PM
    Have you looked in the manuals sub-forum?
  • Skooter
    167
    2,005
    • May 21, 2024 at 1:39 AM
    You don't state which controller - S4C+ or IRC5 M2004. For either, the best manual to find hook up for DSQC328 & other I/O is the controller product manual - procedures.
    For many 'Newbies', getting that green NS on is the hardest.
    Since I have it memorized:
    0V to X1:9, X2:9, X3:9, X4:9
    24VDC to X1:10 & X2:10
    Not sure of your setup but normally if using the 24VDC at XT31 - connect at the output of the 2A fuse or provide a separate 2A fuse.
  • Ali Kavian
    • May 21, 2024 at 11:17 AM
    Quote from Lemster68
    Yes, I used it and it helped me so much, but I still can’t get the output signal.
    Thank you.
  • Ali Kavian
    • May 21, 2024 at 11:42 AM
    Quote from Skooter
    I am using the S4C+ controller, and yes, it took me a long time to set the NS to green, but now the NS is constantly green. I also defined a digital output signal ‘out_ch_1’ and set the value to 1; however, the multimeter doesn’t show any voltage.
    According to the manual, you are right. Pin 9 is 0V, and Pin 10 is 24VDC for X1 and X2. However, when I connect the multimeter to pin X1:10 and X1:9, I still don’t get a voltage.
    Images
      • 352.81 kB
      • 1,600 × 1,200
      • 4
      • 105.3 kB
      • 1,384 × 1,200
      • 2
  • hermann
    404
    2,595
    • May 21, 2024 at 12:58 PM
    Quote from Ali Kavian
    You must provide external 24V to those connectors.
    Standard procedure to be able to connect separated machines / equipment.
    See: https://en.m.wikipedia.org/wiki/Galvanic_isolation
  • Ali Kavian
    • May 21, 2024 at 2:25 PM
    Oh, I thought that the DSQC328 would provide the 24V by itself!
    So, do you mean that I connect a 24VDC from XT.31.2 to the X1:10?
  • Skooter
    167
    2,005
    • May 21, 2024 at 9:34 PM
    Download manuals found here > S4C+ M2000 controller manuals. I suggest reading them all.
    In S4C+ M2000 Product Manual - Procedures, pages 86-87 for XT31. Pages 109-111 for DSQC328.
    The manual should have all the answers. Reach out if you need help with deciphering.
  • IRB140
  • DSQC328
