  4. ABB Robot Forum
Record External axis position as variable
  • MathewWallbank
  • May 19, 2024 at 12:19 AM
  • MathewWallbank
    21
    Robware 3.2 So I dont have SearchExtJ
    I want to record the curent pos of the robot external axis as a variable so i can set the ext axis offset as the difference between 2 points. (Imagine rotating a propeller blade and touch sensing the blades as they come aroundd)
    Can i use cjointT to record a extjoint variable or do i need to pluck it out of a jointtarget with some fancier syntax.
    I think it goes something like
    VAR jointpos_jointpos1 :=(...)
    VAR jointpos_jointpos2 :=(...)
    VAR jointpos_jointposdifference :=(...)
    Var robtarget_posrotateL
    Var robtarget_posrotateR
    VAR extjoint eax_a_extjointpos1:= [0, 0, 0, 0, 0, 0];
    MoleL* !move to start point
    Searchl (posrotateL,*...)
    Jointpos1:= Calcjointt(p1,...)
    Jointpos1.extax.eax_a := extjointpos1
    MoveL* !move back to start point
    Searchl (posrotateR,*...)
    Jointpos2:= Calcjointt(p1,...)
    Jointpos2.extax.eax_a := extjointpos2
    Jposdifference.extax.eax_a := Jointpos1.extax.eax_a + Jointpos2.extax.eax_a
    MoveAbsJ_jointposdifference
    EOffson*;
    HELP!
    (Im dumb)
    MW
  • Lemster68
    301
    2,469
    Blog Articles
    7
    • May 20, 2024 at 3:43 PM
    You can use CJointT but then you will need to extract the ExtJoint values into your ExtJoint variable.
Similar Threads
  • Interrupt Example
    • SkyeFire
    • March 18, 2021 at 8:25 PM
    • Manuals, Software and Tools for KUKA Robots
  • Real Time external control of Kuka using RSI
    • geraldft
    • May 8, 2020 at 7:57 AM
    • KUKA Robot Forum
  • Learning Motoman
    • panic mode
    • September 7, 2023 at 3:21 PM
    • Yaskawa Motoman Robot Forum
  • $POS_INT showing value with track and reference to World system
    • bats
    • August 17, 2020 at 7:48 PM
    • KUKA Robot Forum
