  4. Mitsubishi Robot Forum
I/O Trigger
  • Baymax
  • May 17, 2024 at 9:39 AM
  • Baymax
    Hi All
    I tried to Trigger the output from the robot program in RT Toolbox 3 using the program
    While M_11=1
    If (Deg(J_Curr.J6)<M30) Then
    M_out(12)=Not(M_out(12))
    M_30 = M_30 + M_31
    EndIf
    WEnd
    The problem here is the trigger does not happens at the expected points
    for example: if i move the J6 from -10 to 10 deg and the value of M_30 is -9 and M_31 is 1. The trigger should happens at every 1 deg movement of the J6. The trigger happens but not at every 1 deg movement, for some deg movement it trigger doesn't happens
    If anyone has any ideas, Thanks in advance
  • Lemster68 May 17, 2024 at 2:06 PM
    Approved the thread.
  • Lemster68
    301
    2,472
    Blog Articles
    7
    • May 17, 2024 at 2:07 PM
    It might help is you were to tell us the make of robot and the version of controller.
  • kwakisaki May 17, 2024 at 11:47 PM
    Moved the thread from forum General Discussion of Industrial Robots Only to forum Mitsubishi Robot Forum.
  • Woebot
    5
    24
    • May 18, 2024 at 9:00 AM
    How fast is the robot turing this axis? Maybe in the span of one scan through the program you are just missing a degree. Its not likey but you could try running it from some very slow to very fast speeds and see if you get different results depending on the rotation speed?
    You could also include a counter to tally up all the hits to see if you are getting results on all the degrees but having a signal output timing issue?
    Sorry probably not much help but its an interesting peice of code, I want to try it on a machine at my office.
  • sCZot
    56
    • May 20, 2024 at 7:48 AM
    Hi there, I'm just wondering what the reason for this code is? I get that you want a pulse when the J6 position changes, but what is the use of this information? It's quite possible that the robot is already equipped with some function and you won't have to reinvent the wheel.
  • Baymax
    • June 5, 2024 at 9:30 AM
    Hey, My sincere apologies for the quiet ate reply. The robot model is RV-7FRL-D with CR800D controller
    Quote
  • Baymax
    • June 5, 2024 at 9:40 AM
    Quote from Woebot
    yes I tried to run the robot from min to max speeds but the same results.
    Even I added a counter to the program to verify the number of triggers sent from the program, and I get the exact value as expected.
  • Baymax
    • June 5, 2024 at 9:44 AM
    Quote from sCZot
    Exactly as you said that I need the pulse for 0.5 deg change in J6. I'm new to robots and I'm unable to find any kind of builtin function related to this. If you know anything please let me know where to find :smiling_face:
Similar Threads
  • Functions for ArcTech Commands
    • spacebots
    • May 3, 2024 at 12:52 AM
    • KUKA Robot Forum
  • Advance run stop and Trigger When
    • aknezevi.proton
    • April 15, 2024 at 1:12 PM
    • KUKA Robot Forum
  • Approximating acceleration profiles for PTP motions
    • nicok
    • November 6, 2023 at 5:16 PM
    • KUKA Robot Forum
  • Moving at the same speed indipendently of the percent my robot is running.
    • ToccoEnorme
    • June 1, 2023 at 8:27 AM
    • KUKA Robot Forum
  • Incorrect base shift in the adaptive program
    • DenVer
    • January 28, 2022 at 6:23 PM
    • KUKA Robot Forum
  • How to interpret Torque Monitoring parameters and stop them from updating automatically
    • Agustin Costa
    • November 24, 2021 at 4:04 PM
    • KUKA Robot Forum
  • RSI distance control with ANIN problem.
    • PiotrEDC
    • July 22, 2021 at 6:06 PM
    • KUKA Robot Forum
  • Vision inspection Auto reset code.
    • srtautomation
    • January 14, 2021 at 1:03 AM
    • Fanuc Robot Forum
  • TRIGGER WHEN DISTANCE
