Digital I/O
  • jgmetco
  • May 8, 2024 at 8:14 PM
  • jgmetco
    Working with a Fanuc R-30iB.
    Our IT department asked us to re assign IP addresses for a new line. After changing the ip in this particular Fanuc all of the digital I/O has shifted by 16. So Di1 starting at di 17. Same as true for outputs.
    Any ideas?
  • MOM May 8, 2024 at 8:31 PM
    Approved the thread.
  • jstolaruk
    16
    191
    • May 10, 2024 at 6:47 PM
    Check the configuration mapping for the inputs and outputs.
    Is the I/O real local hardware or I/O from a PLC? If PLC, check the configuration for the PLC, they may have made a change that shifted the info.
  • pdl
    271
    1,548
    • May 10, 2024 at 9:20 PM
    Is IO Auto config disabled?
    $IO_AUTO_CFG=0
    Also, what does your digital IO config page look like?
  • akay98
    13
    • May 23, 2024 at 6:23 PM
    • Clear the current IO Configuration.
    • $IO_AUTO_CFG=0
    • If you have an AoA backup, just try uploading it to get the correct configuration back.
    • Chnage the IP in the Host Comm
    This should bring back your IO configuration and change the IP address also.
Similar Threads
  • PROFINET IO communication between Siemens S7 1512SP PLC and PROFINET FANUC board
    • yolovs
    • August 19, 2022 at 8:28 AM
    • Fanuc Robot Forum
  • Configure Group I/Os with .cm file
    • Andi_33
    • February 22, 2024 at 10:05 AM
    • Fanuc Robot Forum
  • Logic question and Tool Change subprogram
    • kbekkala
    • November 7, 2022 at 8:43 PM
    • KUKA Robot Forum
  • EL4004 analogue output setup with EL6692 I/O Mapping KRC4
    • akaaschool
    • June 15, 2022 at 1:52 PM
    • KUKA Robot Forum
  • Kuka KRC I/O greyed out and DeviceNet error
    • soundwawe
    • April 3, 2022 at 10:53 PM
    • KUKA Robot Forum
  • BK3150 Configuration
    • Robotmei
    • March 20, 2022 at 9:29 AM
    • KUKA Robot Forum
  • Connecting Fanuc robot to PLC via digital input/output
    • fullbang
    • July 28, 2021 at 12:41 PM
    • Fanuc Robot Forum
  • Problem with KUKA gripper communications
    • Magicbot
    • January 14, 2021 at 10:29 AM
    • KUKA Robot Forum
