First of all I would be grateful, if someone points me to more reading materials on the robot and controller.
When I turn on the main breaker - transformer gets powered, but nothing else happens.
Even the fans are not going on (are they controlled by the main cpu?)
I did verify the system boards cage power supply is getting AC power.
I did check the fuse inside the PSU, it is ok.
No LEDs (CPU boards, missed that PSU has it's own leds, can't tell if they work)
and no other signs of life.
Anything I'm missing?
Might it be the robot was connected to an external E-Stop circuit, which now is broken?
Cables from 1KP board go to a set of relays, relay solenoids were powered by some external circuits.
