is there a way to get the irprogammer on the crx robots to look like it does on scara robots? instead of the drag the code blocks I want it to be able to type code into an editor.
CRX irprogammer
james hemmings -
May 3, 2024 at 5:41 AM -
Thread is Resolved
Fubini
May 3, 2024 at 8:09 AM Approved the thread. -
- Best Answer
Yes there is. From Robot Homepage, open iRProgrammer.
Press Menu (top left corner), expand the menu tree:Then under "Browser", select "Editor" and you will have the text editor.
Also, when you hit the menu key, which is on the TP buttons menu, as well as the dropdown that gpunkt posted, you can hit the button on the bottom left. This will change your menu to be the same as a normal, non-CRX, Fanuc.
james hemmings
May 4, 2024 at 2:21 AM Selected a post as the best answer. -
Thank you
