Replace Hand Teach pendant with computer
  • Reckless
  • April 29, 2024 at 4:26 PM
  • MOM
    176
    7
    1,424
    • May 2, 2024 at 11:26 PM
    • #21
    Where did you plug the usb stick in?
  • MOM
    176
    7
    1,424
    • May 2, 2024 at 11:52 PM
    • #22
    Maybe this is a strange idea.
    There is an usb connector at the rear of the robot and two usb connectors (A and B) on the teach pendant.
    The usb connector at the rear should work and the usb connector on the teach panel only works if an usb cable for printers (A and B) is connected between rear and teach pendant
  • Reckless
    104
    • May 3, 2024 at 7:56 AM
    • #23
    Quote from MOM
    so basically find firewire type cable hook it to robot and then put usb drive into b on teach pendant? I will try that but it seems super bizarre to me. need to find one of those old printer cables.
  • MOM
    176
    7
    1,424
    • May 3, 2024 at 9:36 AM
    • #24
    As first step I just would plug the stick into the usb a the back of the robot
  • Reckless
    104
    • May 3, 2024 at 2:34 PM
    • #25
    Tried that last night nothing happened. I believe port was previously used to power a small led light, not sure for what.
  • Reckless
    104
    • May 18, 2024 at 2:29 PM
    • #26
    Quote from MOM
    The teach pendant should be a ADTECH TV5300.
    Have you checked the different menues whether you can find save/load files?
    Yes still no luck.
    TV5600-English-User-mannul-20151030170428.pdf
    TV5600-dispensing-machine-20151028150441-2.pdf
