  4. Stäubli & Bosch Robot Forum
movement anticipation
  • shahryar
  • April 26, 2024 at 7:32 PM
  • shahryar
    hi
    i have a staubli tx90 with cs8c controller i want set/ reset an out put "in a path" not at a stop point in gluing app.i wrote "out1=true" in the first line and "out1= false" in the end of program and between them are movej or movel , ..... but when i run program, output1 will be set and reset immediately because of movement anticipate. if i use "wait end move()" robot will be stop and run and it is problem in gluing.
    is there a solution for it?
    thanks everyone
  • panic mode April 26, 2024 at 7:42 PM
    Approved the thread.
  • Psyril
    18
    83
    • April 27, 2024 at 12:46 AM
    Hello shahryar
    There are different solutions to achieve what you want:
    1. Distance
      If your last motion is something like:
      movej(pLastPosition,tTool,mSpeed)
      you can use an instruction like:
      wait(distance(pLastPosition,here(tTool,fFrame))<100)
      This will not wait until the end of the movement, but until the tool is closer than 100mm to the last position.
    2. moveID
      Every move instruction returns it’s ID in the stack. The instruction getMoveId() returns the moveID of the motion that is currently being performed by the robot. Not only that, but it also returns after the comma the completed percentage of the motion. A return value might be 22.35. This means that 35% of the movement with the ID 22 have been completed.
      nMoveIdToTrack = movej(pLastPosition,tTool,mSpeed)
      wait(getMoveId()>=nMoveIdToTrack+0.6)
      This will not wait until the end of the movement, but until at least 60% of the movement to the tracked position have been completed.
    In both casses make sure it is possible to reach the requested distance/percentage (a big blending might prevent that, use the wait command after a couple of move instructions to ensure that a big blending can be performed).
    The difference between theory and practice is greater in practice than in theory.
  • shahryar
    • April 27, 2024 at 6:42 AM
    thank you very much psyril . i will try these codes.
  • ElEsgalho
    17
    119
    • May 10, 2024 at 12:00 PM
    Psyril Great awnser!
