  4. Stäubli & Bosch Robot Forum
Synchronize the controller of the sensor Kreon KZ25 with the controller of the cobot Staubli TX2-90
  • Vi NTT
  • April 24, 2024 at 3:52 PM
  • Vi NTT
    36
    Hello Everyone,
    Has anyone used a Kreon KZ25 sensor and a Staubli TX2-90 cobot to measure objects? Could you please tell me how to synchronize the controller of the sensor with the controller of the cobot?
    Thank you for your help.
    Regards, Vi.
  • HawkME April 24, 2024 at 3:56 PM
    Approved the thread.
  • ElEsgalho
    17
    119
    • May 10, 2024 at 11:58 AM
    I would say you might need the alter software option.
    I have used alter in the past to move the robot according to an analog input signal.
    I can share some information about the altar if you need it.
  • Vi NTT
    36
    • May 12, 2024 at 10:28 PM
    Hello ElEsgalho,
    Thank you for your response.
    I contacted Kreon. He gave me some indications:
    "The cable between the ECU trigger output and the robot controller input is normally as follows. The robot 'triggers' on rising edges. The signal emitted by the ECU is an open collector signal. The transistor is closed by default and opens when the trigger is sent. It seems to me that you need to connect a pull-up resistor to +24V for it to work.
    ECU trigger output ------------------------------- Robot controller input J111
    9 way D plug -------------------------------- 9 way D plug
    -------------------------------- 2 (signal) + pullup resistor on +24V
    2 -------------------------------- 7 (GND)"
    But I can't find input J111. So, I think it's J212 to replace it.
    If you have any information, could you send it to my email:
    vinguyen247dn@gmail.com
    Thank you very much for your help.
    Best regards,
    Vi
