Hi All,
Is it possible to import a tool model in Roboguide with multiple variations?
The application I am building requires one main gripper cylinder with multiple different fingers that are bolted to the cylinder dependant on the part that is running. Is there a way you can attach a main gripper tool then add different fingers on?
The only way I can think of would be to add the main gripper as a dressout on axis 6 then add the fingers as the gripper (offset correctly).
Thanks,
Josh
