KST_ArcTech_Basic_ weave delay
  • ussr.inv
  • April 21, 2024 at 5:32 PM
  • ussr.inv
    35
    Left weaving delay
    • TRUE: Weave delay is enabled.
    • FALSE: Weave delay is disabled.
    Where can it be changed, for example to 1 second, and how can this be written in the project?
    Edited once, last by ussr.inv (April 22, 2024 at 12:35 PM).
  • ussr.inv
    35
    • April 24, 2024 at 6:30 AM
    Does anyone know :frowning_face: or did I ask the question incorrectly?
  • work_BR
    95
    • April 24, 2024 at 3:09 PM
    Your question does not make sense.
    What contect is your code it? does the robot need to move while you're trying top change your Boolean?
    I'd suggest to supply a code snippet.
    Would it differ from :
    Your_Weave_Delay=TRUE
    Wait Sec 1
    Your_Weave_Delay=FALSE
  • panic mode
    1,299
    13,143
    • April 24, 2024 at 4:26 PM
    the question is too ambiguous...
    ambiguous questions do not get much help and the answers may also be incorrect depending on what others have assumed or guessed (if they could even find some plausible interpretation)
    first of all - clearly this is a software related question, yet software versions are not mentioned. sadly this is a such common problem that it has lead to creation of pinned topic READ FIRST.
    "left weaving delay" can be interpreted differently. for example:
    it could be interpreted as starting motion without weaving and then a bit later (as the move is still in progress) start weaving.
    but it could also be interpreted as altering the weave pattern, by adding delay to weave swing to the left.
    etc.
  • ussr.inv
    35
    • April 25, 2024 at 6:58 AM
    Quote from panic mode
    etc.
    Option two. Changing the weave pattern by adding a delay at the edges of each weave. I just worked with Yaskawa robots, where, for example, if you don’t use the built-in weaving trigger in which you can manually add a delay along the edges, you can also transfer the delay directly with a certain command (like a system variable).
    How can I do this on Kuka krc 4 version 8.6.6 Roughly speaking, I have two points of linear motion created by the built-in Kuka form. I indicated in the trigger the length of the weave, the pitch, and the type of weave. The KST_ArcTech_Basic documentation says
    ArcWeavePattern[cArcUserFigure1].Tech1.LDelay.Active = FALSE
    ArcWeavePattern[cArcUserFigure1].Tech1.RDelay.Active = FALSE
    change to TRUE, then at the ends of the weave it will be possible to enter a stop for a certain time.
    I changed FALSE to TRUE as described. Question. Should some delay block appear in the built-in weave trigger? or is it implemented like that in a different way. And another question is whether I can pass data to the built-in weave trigger as a variable and not manually. For example, set the length of the weave and the pitch of the variable?
