Setting Tool System Variable using Karel
  • Shubham Malhotra
  • April 19, 2024 at 11:44 PM
  • Shubham Malhotra
    21
    My robot in Roboguide is CRX-10iA/L
    I am using Karel to get and set tool frame value. This is my piece of code
        PosTool : XYZWPR
                        CASE(6): -- 'get_tool' request
                            WRITE('get_tool request',cr)
                            GET_VAR(entry, '*SYSTEM*', '$MNUTOOL[1,2]', PosTool, status)
                            IF status <> 0 THEN
                                POST_ERR(status, '', 0, 2)
                            ENDIF
    I am getting the error
    INTP-342 ABORT (%s^4, %d^5) Incompatible variable
    Cause: KAREL program error. The data type defined by the BYNAME function and the variable
    type are mismatched.
    Remedy: Make sure you have the correct data type and variable type.
    I have tried every data type for PosTool but getting the same error.
    I am out of ideas.
    Any help is appreciated
  • 95devils April 19, 2024 at 11:53 PM
    Approved the thread.
  • hoitzing
    24
    128
    • April 22, 2024 at 8:04 AM
    The correct datatype is POSITION. The code you posted works for me when using this datatype.
  • Shubham Malhotra
    21
    • April 22, 2024 at 1:59 PM
    hoitzing Do you see the updated value in the variable after it has been set?
  • hoitzing
    24
    128
    • April 22, 2024 at 2:38 PM
    I have only tried the GET_VAR routine as in the example code you posted; if you have issues with the SET_VAR routine you should post the relevant code.
  • Shubham Malhotra
    21
    • April 25, 2024 at 3:28 PM
    Thank you, the it works with POSITION Data Type.
Similar Threads
  • Main difference kuka/fanuc, "Tribal knowledge" and generic good to know fanuc stuff
    • Hes
    • November 3, 2023 at 6:56 PM
    • Fanuc Robot Forum
