  4. Denso Robot Forum
Angled WorkPlace with a SCARA HSR-065A1-N20-RC8A
  • Mr.Question
  • April 18, 2024 at 1:56 PM
  • Mr.Question
    33
    So I am working with a ROBOT DENSO SCARA HSR-065A1-N20-RC8A.
    There are 3 workplaces with an angle of 80º (from base).
    I need that when the robot is on those workplaces and I move the Z axis it follows that angle.
    Can't find a way to move the robot based on the WorkPlace Coordinate System that I define. Only XYZ, Joint or Tool
  • Johnny B
    15
    • April 30, 2024 at 8:47 PM
    I'm struggling to visualize what you are trying to do. Maybe attach a sketch or something.
    With XYZ, RX, RY, and RZ, you can locate and angle work planes six ways from Sunday.
  • RobotWizard
    Robot Specialist
    7
    • March 3, 2025 at 8:57 PM
    It sounds like you should use a new work coordinate system. By using work 1-7 you change the user coordinate system. Work 0 is the base of the arm (this cannot be changed).
  • Lomba1986
    8
    • April 8, 2025 at 7:57 AM
    Dear Mr.Question, before move select the work using command Changework n where n is the number of work (from 0(base of robot) to 7)
    After this selection you move using Draw command if you need a relative movement or Dev if you want shift a position P using the orientation of these work
  • angle
  • coordinate system
