Fanuc EOAT IO LINK connection
  • Robo_NewBie
  • April 17, 2024 at 4:06 PM
  • Robo_NewBie
    52
    Greetings of the day everyone,
    I have a R30iB plus controller. The robot is a material Handler with the EOAT with IO LINK. Do anyone know how to communicate it to Fanuc Robot ?
    MANIFOLD - FESTO VAEM-L1-S-8-PT
    BLOCK - BALLUF - BNI EIP 508 005 Z015 013
    thank you.
  • PnsStarter
    92
    330
    • April 17, 2024 at 5:25 PM
    Quote from Robo_NewBie
    That one uses ethernet/ip!
    EOAT with IO LINK.
    Are you sure?
    First, please check you're setup/hardware...
    Backdate/TP-Tools: A small collection of tools that simplify the commissioning and programming of Fanuc robots. (github.com)
  • jstolaruk
    16
    189
    • April 23, 2024 at 7:50 PM
    Ethernet/IP but each port can be configured for IO-Link. I've used it with a PLC but not sure if it can be used with a robot.
    https://publications.balluff.com/pdfengine/pdf?type=pdb&id=290894&con=en
  • pdl
    269
    1,530
    • April 23, 2024 at 8:22 PM
    I have used IFM Ethernet/IP IO-Link masters several times with a Fanuc.
    In each case, the robot was configured as the EIP scanner. I had no issues with the setup when I followed the Fanuc EIP setup and operations manual (MAROU91EN02171E).
  • jstolaruk
    16
    189
    • May 3, 2024 at 3:25 PM
    Quote from pdl
    Were any of the ports configured for IO link? I sometimes would like to directly interface to a pressure switch supporting IO-Link.
  • pdl
    269
    1,530
    • May 3, 2024 at 4:31 PM
    All of the ports are able to be configured as IO Link. It just depends on what type of device you plug into the port. I have used them with both standard and IO Link devices.
    Ethernet/IP is just the fieldbus used to communicate with the module.
  • jstolaruk
    16
    189
    • May 6, 2024 at 7:49 PM
    Quote from pdl
    Sorry, let me re-word that question:
    If I set up the robot as the ethernet/ip scanner and the IO-Link master as an ethernet/ip adapter AND then configure one of the ports for IO-Link AND then connect a IO-Link pressure switch to that port, can the robot see the pressure reading?
    I always use a PLC acting as cell controller and central point for I/O then distribute the information to other devices as needed but it might come in handy for a direct connection.
  • pdl
    269
    1,530
    • May 8, 2024 at 2:41 PM
    Yes. You would just map that input as a group input.
    Everything will be addressed through rack 89, Ethernet/IP. The start point and number of points will have to be addressed according to the byte map of the device, which can often be found in the IODD.
    It's really easy of you've ever setup group I/O on a Fanuc before.
  • jstolaruk
    16
    189
    • May 8, 2024 at 5:16 PM
    Thanks, good to know if I ever have to do that. I normally would connect the I/O-Link master to a PLC and then filter out the junk and send the reading via group i/o to the robot, but it might be helpful in the future to know I can go direct.
  • IO-Link
  • R30ib plus
