  4. ABB Robot Forum
Help Needed in complex abb robot logic
  • Ryuk7
  • April 17, 2024 at 3:05 PM
  • Ryuk7
    36
    Hi everyone
    I'm working on a ABB robot project which have multiple size of components and multiple types of attachments . We have not using the vision system for identifying attachments
    Robot cycle will be like - A operator select size and components combination to be attached then robot will select Case of size after it will select component and after picking up component he will add next case value to register of position
    as we are not having vision positions are manually teach and i have to mark each position as a case ..
    this will cause many programs and many resisters used . My question is is there any better way to program this condition. thank you
    attaching Kind of logic iam have thinking about. is there any better way to do this type of logic or shall i continue with TEST CASE
    PROC main()
    TEST SIZE_SELECTION
    CASE 1:
    SIZE_15MM_PROG;
    CASE 2:
    SIZE_20MM_PROG;
    CASE 3:
    SIZE_25MM_PROG;
    continued till case 10 ....
    TEST Component SELECTION
    PROC SIZE_15MM_PROG()
    CASE 1:
    Component_1_Prog;
    CASE 2:
    Component_2_Prog;
    CASE 3:
    Component_3_Prog;
    contined till case 10 .....
    TEST COMP_1_POSITION
    CASE 1:
    Pickup Position 1 Point ( MOV L mov J whatever )
    COMP_1_POSITION = 2
    CASE 2:
    COMP_1_POSITION = 3
    CASE 3:
    COMP_1_POSITION = 4
    contined till case 10 ..... and in 10th case I move COMP_1_POSITION = 1
    I'm No One, I Don't Want To Be Anyone.
  • nicolahinssen
    • April 19, 2024 at 5:48 AM
    You can use late binding to replace your CASE clauses. For example:
    % "Component_" + NumToStr(Component, 0) + "_Prog" %;
    The IRC5 Technical Reference Manual: RAPID Overview explains this concept.
