Have a program issue
  • ktmark
  • April 13, 2024 at 8:14 PM
  • ktmark
    8
    135
    i. Don't know where to put this thread
    But I have a fanuc arcmate 100 and have a robot with a program in it the operator did something to it so I went to go to man fctn to go home but some how hit thd wrong key. It now only has I line in thd edit program. This program has an A side and a B side I was on the B side when this happened the A side still currently works but the B side does not it moves rwal slow when I go into edit I has only 1 line but what really surprises me is any program that is on the B side foes the same thing only 1 line. What happen. Thanks
  • HawkME
    568
    3,268
    • April 15, 2024 at 12:34 PM
    Can you post the A and B programs?
  • ktmark
    8
    135
    • April 15, 2024 at 2:02 PM
    yes I will thanks
  • ktmark
    8
    135
    • April 15, 2024 at 9:48 PM
    the first one is side a I have to hit cycle start to pull up the lines in edit
    The second one is side b same thing but no edit lines
    Images
      • 512.17 kB
      • 1,200 × 1,600
      • 20
      • 550.86 kB
      • 1,600 × 1,200
      • 19
  • ktmark
    8
    135
    • April 15, 2024 at 10:21 PM
    looks like the B side is the fieat picture.
    Can you or acces the program with lines on it without going in cycle start mode thanks. Again
  • HawkME
    568
    3,268
    • April 16, 2024 at 12:04 AM
    Do you have any previous backups?
  • ktmark
    8
    135
    • April 16, 2024 at 12:50 AM
    unfortunately I don't think so is there a way I can access the program lines without hitting cycle start and or would the cycle start button hinder the B side if it's not working. Just A thought thanks.
  • HawkME
    568
    3,268
    • April 16, 2024 at 2:24 AM
    You just press select and then highlight the program and press enter.
    It sounds like you would benefit greatly from some basic robotics training. You need to learn how to navigate the menu and take backups.
  • ktmark
    8
    135
    • April 16, 2024 at 3:33 AM
    yep I sure do. I will do that tomorrow I do need training thanks 😊
  • ktmark
    8
    135
    • April 17, 2024 at 11:37 PM
    I did that the program Is in there for the B side. I entered it. Yet I'm not able to access or see the program lines for that side. Does that make sense ?
  • HawkME
    568
    3,268
    • April 18, 2024 at 2:08 AM
    • #11
    Not really. Unless they are all deleted.
    Can you send a backup or copy of the .ls files for that program.
Similar Threads
  • User Frame to PR Question
    • CLanford_Conmet
    • March 14, 2024 at 7:52 PM
    • Fanuc Robot Forum
  • Unit Load layer 1 drops are all too high
    • MONIQUEZE
    • March 14, 2024 at 6:46 PM
    • Fanuc Robot Forum
  • Issue with $OV_PRO Command in Robot Program
    • AD3MIN
    • March 15, 2024 at 12:04 PM
    • KUKA Robot Forum
  • Fanuc time out issue
    • R2D2:)
    • February 5, 2024 at 2:52 PM
    • Fanuc Robot Forum
  • TCP/IP errors halts the program instead of returning the error code
    • robotreto
    • June 6, 2023 at 8:27 PM
    • Kawasaki Robot Forum
  • Any suggestion how to resolve KSS01205 Ackn.: Interpolation cycle timeout monitoring LRS_HP issue
    • Aivaras Narbutas
    • September 11, 2023 at 3:43 PM
    • KUKA Robot Forum
  • FANUC R-30iA Program already running fault after power cycle
    • AKAEA
    • May 27, 2023 at 2:47 AM
    • Fanuc Robot Forum
  • Fanuc 30iB controller locks up
    • kdkoadd
    • January 3, 2023 at 12:39 PM
    • Fanuc Robot Forum
  • Dynamic control of FANUC Robot in Run-Time
    • Gokul N A
    • July 3, 2019 at 10:39 AM
    • Fanuc Robot Forum
  • Program stuck executing motion command (LIN_REL), but robot is not moving.
    • RoboterEST
    • July 15, 2021 at 8:50 AM
    • KUKA Robot Forum
