XHOME SPEED CHANGE OPTION GREYED OUT
  • Darkhorse
  • April 8, 2024 at 7:11 PM
  • Darkhorse
    17
    Hi everyone,
    I am trying to update XHOME speed on teach pendant and as well as on WV but both places options are greyed out, not sure why
    TP: Change option greyed out only for XHOME but I can change any other inline moves
    WV: "Change instruction" option greyed out but available for any other moves
    Here's my move
    ;FOLD PTP HOME Vel= 100 % DEFAULT;%{PE}%MKUKATPBASIS,%CMOVE,%VPTP,%P 1:PTP, 2:HOME, 3:, 5:100, 7:DEFAULT
    $BWDSTART = FALSE
    PDAT_ACT=PDEFAULT
    FDAT_ACT=FHOME
    BAS (#PTP_PARAMS,100 )
    $H_POS=XHOME
    PTP XHOME
    ;ENDFOLD
    TIA
    panic mode
    1,267
    13,037
    • April 8, 2024 at 7:21 PM
    you are asking software related question but you did not state software versions.
    are we suppose to guess? did you check Rights Management? maybe you need to login to access certain functionality. did you try creating new inline form from scratch?
    here is an example of PTP HOME on KSS8.7:
    ;FOLD PTP HOME Vel=100 % DEFAULT ;%{PE}
    ;FOLD Parameters ;%{h}
    ;Params IlfProvider=kukaroboter.basistech.inlineforms.movement.old; Kuka.IsGlobalPoint=False; Kuka.PointName=HOME; Kuka.BlendingEnabled=False; Kuka.MoveDataPtpName=DEFAULT; Kuka.VelocityPtp=100; Kuka.CurrentCDSetIndex=0; Kuka.MovementParameterFieldEnabled=True; IlfCommand=PTP
    ;ENDFOLD
    $BWDSTART = FALSE
    PDAT_ACT = PDEFAULT
    FDAT_ACT = FHOME
    BAS(#PTP_PARAMS, 100.0)
    SET_CD_PARAMS (0)
    PTP XHOME
    ;ENDFOLD
  • Darkhorse
    17
    • April 8, 2024 at 7:46 PM
    Thanks panic mode.
    Sorry, here it is
    WV version 6.025
    KSS 8.6.8
    Controller KRC4
    I do see lots of option on rights management but not seeing relevant parameters to change. I did try log in as admin and change the speed but same as before, it is still greyed out.
    panic mode
    1,267
    13,037
    • April 8, 2024 at 8:13 PM
    i just tried it on the robot running 8.7 and no problem...
    if not logged in, Change is grayed out. this is expected since global point and in the Rights Management default is that touchup of global points requires at least Expert level.
    if logged in as Expert, Change button is enabled and it works...
    panic mode
    1,267
    13,037
    • April 8, 2024 at 8:15 PM
  • Darkhorse
    17
    • April 8, 2024 at 8:34 PM
    Thanks. Tried that but no luck. Logged in as expert and still greyed out.
    Images
      • 109.66 kB
      • 675 × 1,200
      • 9
      • 117.77 kB
      • 675 × 1,200
      • 7
  • DS186
    199
    1,051
    • April 8, 2024 at 9:28 PM
    Did you activate the setting "Teach/modify global points" in the rights management?
    Post
    RE: About kuka Global points
    You have to change the setting of "Teach/modify global points" in the rights management. By default it is deactivated.
    DS186
    February 16, 2024 at 11:46 PM
    EDIT: Sorry, I missed your screenshot. Forget about my question.
  • Hes
    40
    238
    • April 9, 2024 at 9:49 PM
    Quote from panic mode
    Just out of curiosity, what is the program to the left in your screenshot?
    panic mode
    1,267
    13,037
    • April 10, 2024 at 1:14 AM
    it is just one of my...creations... this one i named Krcko (short for Krc Kompanion).
    don't want to hijack the thread so i put it into a PDF
    Files
    krcko.pdf 379.23 kB – 18 Downloads
  • KSS8.6.8
