Changing welding parameters while welding in Auto Mode FANUC
  • Tarun goyal
  • April 8, 2024 at 11:49 AM
  • Tarun goyal
    27
    *************Equipment details*********
    Make: Fanuc
    Manipulator: Arcmate 100iC/8L
    Robot controller : R30iB Plus
    Weld Power Source Make : Lincoln
    Weld Power Source : Power Wave® R450 Robotic Power Source.
    PLC - Allen Bradley - Compact Logix 5380
    Communication protocol - Ethernet (PLC -> Fanuc robot controller -> Lincoln Weld Powersource)
    *****************END*********************
    Can anyone tell me the variables for the weld parameters ?
    e.g. I know the variable for Travel Speed i.e. $AWESCH[1,16].$CMD_WSPEED
    I want to know the variables for wire feed speed and Trim
    Thanks in Advance :smiling_face:
    Edited once, last by Tarun goyal (April 8, 2024 at 2:00 PM).
  • Tarun goyal
    27
    • April 18, 2024 at 11:59 AM
    I tried changing the value of the variable, but apparently once the welding has started the changed value will not reflect on the robot.
    So, is there a way, where I can change the weld parameters while welding?
  • dcwelder
    38
    • April 18, 2024 at 2:47 PM
    Does your Teach Pendant have a button labeled "OTF"? That is the On The Fly button, and if you press this, it will pull up the welding parameters you are using during a weld, and you can change them On The Fly.
  • Tarun goyal
    27
    • April 24, 2024 at 12:07 PM
    Quote from dcwelder
    Hi thanks for replying , Yes i do have the button but it will be manual right ? like I have to do it manually on the pendant . But is there a way to do it remotly like by a PLC ?
  • dcwelder
    38
    • April 25, 2024 at 12:31 AM
    Quote from Tarun goyal
    Yes it would be manual. I unfortunately don't know of a way to do it remotely through a PLC.
    Sorry.
  • Tarun goyal
    27
    • April 25, 2024 at 7:12 AM
    Thats OK, if you get any lead kindly let me know , it will be of great help
    THANKS:smiling_face:
  • Lincoln
  • lincoln electric
