Welding Circular Path
  • GaliRob
  • April 3, 2024 at 11:48 AM
  • GaliRob
    25
    Hello all,
    I'm integrating a FANUC robot, model R2000iC-165F for a laser welding application and I'm having some problems with circular trajectories.
    When we try to weld small circles or trajectories with small circular radius... the result is not as expected. It's like an oval.
    And this result is with fast... and slow speed.
    Robot has the payload calculated (with robot), we installed Adv-Ctrl Speed and Adv-Ctrl Path, also we tried with more points in the trajectory but at the end it's equal.
    I attach a picture with the programmed points and the result.
    Any advice for programming circles with FANUC?
  • GaliRob
    25
    • April 3, 2024 at 11:56 AM
    image 1 charset="utf-8"></script>m
    gur.com/adrwl5kimage 2
  • Werner Hampel April 3, 2024 at 1:53 PM
    Approved the thread.
  • KyleAR
    • April 3, 2024 at 2:57 PM
    I'm by no means an expert and still learning but how confident are you in your TCP? That would be the first thing I would check for this.
    If the TCP seems perfect then I would try finding a similar sized circle and manually teach points going around it. Does this problem still occur if you run the taught program?
    My third attempt to trouble shoot this would be to actually try it with less points. In my job im working with bigger circles (>=12" pipe) but most of the time we are doing significantly less points than this. I wonder if the problem would occur using just 2 circular moves to complete the weld.
    This is a strange one for sure, never seen circle movements be this wavy.just some tips I would try to troubleshoot this with, take it or leave it. Let me know if I've said something wrong, I'm trying to learn more being on here
  • HawkME
    570
    3,270
    • April 3, 2024 at 7:24 PM
    Small circles are problematic with articulated arm robots. Generally you shouldn't expect them to be great. It's caused by compounding backlash in the joints.
    Show your code of what you have attempted. Have you tried using the actual circle or Arc movement type.
    There is also a paid option you can install called "Small Circle Accuracy" that can improve results.
  • GaliRob
    25
    • April 9, 2024 at 1:48 PM
    Hi
    KyleAR: measure the tcp of a laser head is quiet complicate, I got it by Roboguide like an approximated tcp. Then I measured another tcp in a spike. Created a point on the working table with a measured frame and then compared both tcps going to a point. After it, i made some corrections to achieve a better tcp.
    Also in my opinion and after some tests, i think it's better with less points.
    HawkME: yes, as you say backlash is a problem, and more in this kind of tasks, also a big robot is not the best choice to achieve great circles.
    Small Circle Accuracy is not supported in this robot.
    I post the code:
    1:  !****************************** ;
    2:  !*        PROGRAM:           * ;
    3:  !*        CIRCLES             * ;
    4:  !****************************** ;
    5:   ;
    6:  UTOOL_NUM=1 ;
    7:  UFRAME_NUM=1 ;
    8:  PAYLOAD[1:Laser] ;
    9:  OVERRIDE=100% ;
    10:   ;
    11:J P[1: ] 50% CNT100    ;
    12:L P[2] 50mm/sec CNT100 ACC100    ;
    13:   ;
    14:L P[3] 50mm/sec CD20 PSPD100    ;
    15:C P[4]
    :  P[5] 50mm/sec CD20 PSPD100    ;
    16:C P[6]
    :  P[7] 50mm/sec CD20 PSPD100    ;
    17:C P[8]
    :  P[9] 50mm/sec CD20 PSPD100    ;
    18:   ;
    19:L P[10] 50mm/sec CNT100    ;
    20:   ;
    21:L P[11] 50mm/sec CD20 PSPD100    ;
    22:C P[12]
    :  P[13] 50mm/sec CD20 PSPD100    ;
    23:C P[14]
    :  P[15] 50mm/sec CD20 PSPD100    ;
    24:C P[16]
    :  P[17] 50mm/sec CD20 PSPD100    ;
    25:C P[18]
    :  P[19] 50mm/sec CD20 PSPD100    ;
    26:C P[20]
    :  P[21] 50mm/sec CD20 PSPD100    ;
    27:C P[22]
    :  P[23] 50mm/sec CD20 PSPD100    ;
    28:C P[24]
    :  P[25] 50mm/sec CD20 PSPD100    ;
    29:C P[26]
    :  P[27] 50mm/sec CD20 PSPD100    ;
    30:C P[28]
    31:C P[14]
    32:C P[16]
    33:   ;
    34:C P[18]
    35:   ;
    36:L P[29] 50mm/sec FINE    ;
    37:   ;
    38:  !Access ;
    39:J P[1: ] 25% CNT100    ;
    40:   ;
  • HawkME
    570
    3,270
    • April 10, 2024 at 12:59 AM
    Your start and stop point of the circle need to be FINE moves.
    I would suggest the moves on lines 14, 17, 21, & 34 (line Numbers in black above) be Fine, all circular moves in between those could be CNT100 if you want.
    Take a backup first before doing any trials.
  • GaliRob
    25
    • April 10, 2024 at 6:30 AM
    The welding process must be constant from the beginning till the end. Thats why the it no FINE moves in the code.
  • HawkME
    570
    3,270
    • April 10, 2024 at 2:48 PM
    I'm not a robotic welding expert so maybe someone else can give some insight.
    But I can tell you this, the circular move won't make a circular shape unless the start and end are Fine or pretty close. You might get away with CNT5.
  • DawnHill
    13
    • April 11, 2024 at 2:45 AM
    I wonder to know what is the value of small circular radius?
  • GaliRob
    25
    • April 11, 2024 at 1:47 PM
    So, to make circles the start and end points must be fines. :thinking_face:
    Something like this:
    1:  UTOOL_NUM=1 ;
    2:  UFRAME_NUM=1 ;
    3:  PAYLOAD[1] ;
    4:  OVERRIDE=100% ;
    5:   ;
    6:L P[3:pApro] 50mm/sec CNT100 ACC100    ;
    7:  !Welding circle ;
    8:   ;
    9:L P[4:pStart] 50mm/sec FINE PSPD100    ;
    10:C P[5:pCirc1Aux]
    :  P[6:pCirc] 50mm/sec CD5 PSPD100    ;
    11:C P[7:pCirc2Aux]
    :  P[8:pCirc2] 50mm/sec FINE PSPD100    ;
    12:   ;
    13:L P[3:pApro] 50mm/sec CNT100 ACC100    ;
  • GaliRob
    25
    • April 11, 2024 at 2:01 PM
    • #11
    Quote from DawnHill
    Radius: 10 mm.
    In the trajectory there are straight lines, circular trajectory and also circles. The smallest radius is 10 mm.
  • HawkME
    570
    3,270
    • April 11, 2024 at 11:59 PM
    • #12
    Right but your intermediate points can be CNT100, such as P[6], instead of CD5.
  • DawnHill
    13
    • April 12, 2024 at 3:37 AM
    • #13
    Quote from GaliRob
    Radius: 10 mm.
    thanks
  • Reflex
    133
    • April 25, 2024 at 4:15 PM
    • #14
    i don't know if you already loock to ORNT_BASE instruction ?
  • GaliRob
    25
    • May 3, 2024 at 1:36 PM
    • #15
    Quote from Reflex
    Hi, I don't see that instruction. Should it be enabled anywhere? :thinking_face:
  • Reflex
    133
    • May 7, 2024 at 9:39 PM
    • #16
    Quote from GaliRob
    What's your handlingtool version ?
Similar Threads
  • Kawasaki FS10E Robot arm Motor Power issue
    • triumpster
    • June 1, 2023 at 3:59 AM
    • Kawasaki Robot Forum
  • Rotational speed of fanuc positioner for welding
    • TomFoolious
    • February 21, 2020 at 12:46 PM
    • Fanuc Robot Forum
  • TCP ORientation Change while Maintaining Constant TCP Speed
    • NJPOrozco
    • January 21, 2022 at 12:28 PM
    • KUKA Robot Forum
  • weld
  • Accuracy
  • CIRC
