Kuka.Sim 4.3 $ACT_POS_MES not working
  • sloopkogel
  • March 27, 2024 at 11:07 AM
  • Fubini
    272
    1,871
    • March 30, 2024 at 5:44 PM
    • #21
    So you have 2 absolute positions p1 and p2. Assuming they have same base and tool then inv_pos(p1):p2 is the shift/distance in the tool system. If you want to it with repect to base then p1:inv_pos(p2) is the shift in the base system.
    This can also be applied if base and tool are different. If you use forum search you can also find how to use the geometric operator : in combination with inv_pos to change positions to different bases or tools.
    If you have already absolute positions I do not understand what does not allow you to use them directly.
    Fubini
  • MOM
    175
    7
    1,418
    • March 30, 2024 at 7:01 PM
    • #22
    In the System variables documentation the difference is listed:
    $POS_ACT
    Actual Robot Position commanded
    $POS_ACT_MES:
    Acual Robot Position measured
  • sloopkogel
    34
    • March 31, 2024 at 6:50 PM
    • #23
    My previous posts might have been a bit confusing. I wanted to use the same program (Pick() and Place()) for both automatic and manual mode. That's why I needed the motion to be able to blend. I have since split up the program in automatic and manual sequence so there is no need for blending with $POS_ACT_MES anymore
    SkyeFire
    1,039
    9,375
    • April 1, 2024 at 3:33 PM
    • #24
    Quote from work_BR
    No, $IN[1025]. In the sim it's false and in the KRC it's true.
    Just for a giggle, I checked this on an OfficePC, and $IN[1025] is TRUE in that environment. So using this trick will be context-dependent.
Users Viewing This Thread
  • 1 Guest
