Motion Blending Info Shared
  • jaiiyer
  • March 26, 2024 at 6:42 PM
  • jaiiyer
    15
    91
    Hi All,
    Recently I was spending some time learning motion blending in KUKA. I am attaching the files that I found useful
    1) Expert_Programming_manual: Explains the motion blending in details.
    2) Motion Blending KUKA.xls: Its English translate of Überschleifen-Kreuzvergleich.xls that Fubini shared.
    3) SIM_model_to_learn_motion_blending: Its shared as .txt but convert to .vcmx and open with KUKA SIM. Here you can change the motion blending parameters C_DIS, C_PTP etc and see how it affects the total time. Also you can change the $ADVANCE and see how the instructions are executed.
    If moderator finds this info useless then apologies and can be deleted.
    Files
    SIM_model_to_learn_motion_blending.txt 2.86 MB – 23 Downloads Expert_Programming_manual.pdf 2.8 MB – 105 Downloads
  • jaiiyer
    15
    91
    • March 26, 2024 at 6:43 PM
    Quote from jaiiyer
    Files
    Motion Blending KUKA.xlsx 17.41 kB – 13 Downloads
  • jaiiyer
    15
    91
    Thanks Fubini for your on going help
  • jaiiyer
    15
    91
    • March 26, 2024 at 6:45 PM
    Quote from jaiiyer
    I have defined a variable PATH which shows which path the robot is following. See how it changes when you change $ADVANCE
