Hello, everyone.
I had a problem with my KRC4 KPP 600-20-3X20 driver, so i need to chenge it.
Is there any SW configuration that I have to do to replace this part or it is just plug and place?
Best Regards.
KPP 600-20-3X20 INSTALATION
ISMAILES -
March 5, 2024 at 5:26 PM -
Fubini
March 5, 2024 at 6:20 PM Approved the thread. -
Hello, everyone.
Best Regards.If the KPP is the only component that you will change, it should be ok. It is plug and play when exchanging with the component of the same type. Only when you need to change multiple components, it should be changed one by one due to correct FSoE addressing of the components.
If replacement is the same part, and you are only exchanging single unit between powerups, no software change is needed. KRC will detect and configure replaced unit automatically.
software is needed when two units from same controller are swapped around (both existed in that KRC before and after swap), or when multiple units (2+) have been exchanged at once.
