Communication between KUKA KRC5 Controller with Omron NX1P2
  • adityapratama
  • March 4, 2024 at 9:20 AM
  • adityapratama
    7
    Hi!
    Currently I have a project that will be using 3 robots (using KR C5 controller) and 1 PLC (Omron NX1P2).
    I plan to use EL6692 as bridge to do a communication between the robots and PLC.
    Beside the communication, the PLC will use EtherCAT to control 3 units of servo motor.
    Is there any problem if I am using this configuration? I want to make sure that the communication will work without any problem.
    You can see the topology here.
    Thank you.
  • adityapratama March 4, 2024 at 9:21 AM
    Changed the title of the thread from “Communication between KUKA KR C5 Controller with Omron NX1P2” to “Communication between KUKA KRC5 Controller with Omron NX1P2”.
  • MOM March 4, 2024 at 9:55 AM
    Approved the thread.
  • panic mode
    1,278
    13,079
    • March 4, 2024 at 7:55 PM
    that is good... it shows PLC side network, KRC side is not shown but it will be same for each robot - connection from CCU.X44 to EK1100 (which is primary side bus for Bridge)
  • adityapratama
    7
    • March 5, 2024 at 8:08 PM
    I think for KR C5, the primary side bus for bridge will connected to [KEI] Extension Interface (XF8) right?
    I make a clearer image for the topology.
    I want to make sure again about this, is there any concern about this ethercat topology both from PLC and robot side?
    Thank you.
  • panic mode
    1,278
    13,079
    • March 5, 2024 at 8:54 PM
    you are correct, on KRC5 they call it KEI...
  • adityapratama
    7
    • March 6, 2024 at 12:49 AM
    Thank you.
    I am sorry that I am very new to KUKA Robot and EtherCAT communication.
    This system will work properly both for PLC side and robot side right?
  • panic mode
    1,278
    13,079
    • March 6, 2024 at 1:04 AM
    Yes... You have correct idea
  • adityapratama
    7
    • March 6, 2024 at 5:19 PM
    Thank you for your help.
  • omron
  • EtherCAT
