Remote motion interface
  • Aermoe
  • February 29, 2024 at 1:56 PM
  • Aermoe
    21
    Does anybody here have any experience with the remote motion interface option?
    My local Fanuc tech support does not provide much help.
    I have the operator manual for the option and it tells me which packets to send when, but it does not tell me how one configures RMI in the robot? I am testing it with a (homemade) VB.NET program to send the packets to my roboguide simulation. Packets are being sent to port 16001.
    When I try to send the 'connect' packet the controller in roboguide goes into fatal error and needs to reboot.
    Errorcode: System error 640001,c000005 at 55bb3c9f
    Power off controller to reset.
    So I'm guessing the robot needs some configuration to make this possible? Also does the robot need to be in run/ specific program/....
    Anybody with some insight on this vague option?
  • Lemster68 February 29, 2024 at 2:59 PM
    Approved the thread.
  • ywkwon
    • June 24, 2024 at 2:11 PM
    Hi, I am facing the same issue, did you figure it out ?
  • Aermoe
    21
    • June 25, 2024 at 1:37 PM
    Quote from ywkwon
    Hi, yes I managed to get it working.
    If I remember correctly it was due to a syntax error in the string that I sent. Pay attention to the " (Ascii character 34) and the /r/n (which is actually a new line).
    This is the VB code that makes the connection string and this works:
    sendString = "{" + Chr(34) + "Communication" + Chr(34) + ":" + Chr(34) + "FRC_Connect" + Chr(34) + "}" + Environment.NewLine
  • ywkwon
    • June 25, 2024 at 2:25 PM
    I will check it with C# code. thank you
  • ywkwon
    • June 26, 2024 at 1:49 AM
    TcpClient tc = new TcpClient("127.0.0.1", 16001);
    string msg = "{\"Communication\" : \"FRC_Connect\"} \r\n";
    I successfully connected with the help of Aermoe:thumbs_up:
    Return Message
    {"Communication" : "FRC_Connect", "ErrorID" : 0, "PortNumber" : 16002, "MajorVersion" : 3, "MinorVersion" : 0}
    Edited 2 times, last by ywkwon (June 26, 2024 at 1:56 AM).
  • Djibril Benaissa
    • July 18, 2024 at 10:11 AM
    I am also trying to work with the RMI Option. How did you know the port number you needed to send the packets ?
    Thank you very much for your help
  • Aermoe
    21
    • July 19, 2024 at 9:32 AM
    Quote from Djibril Benaissa
    Hi there
    It's in the manual. The first connection request you have to send to port 16001. This starts the RMI option. Then you have to send another connection request to port 16002 (normally the robot replies the first connection request with the port that should be connected to in the 2nd request). But I think it's always 16002.
Similar Threads
  • How to use RMI and RSI options together
    • houssam.larbi
    • June 14, 2023 at 9:53 AM
    • Fanuc Robot Forum
  • CS8C configure profibus dio in iomap.cf
    • aknezevi.proton
    • November 21, 2023 at 8:20 AM
    • Stäubli & Bosch Robot Forum
  • Roboguide - Profiler speed
    • GaliRob
    • October 29, 2023 at 12:52 PM
    • Fanuc Robot Forum
  • Ideas for Weld Repair System
    • AlejandroOrtiz
    • October 4, 2023 at 5:00 PM
    • Fanuc Robot Forum
  • Issues with Initial Setup / Jogging
    • ekumar
    • September 20, 2023 at 8:49 PM
    • Fanuc Robot Forum
  • Control my Kuka robots totally with PC client with Qt and C++
    • yen_like_capoo
    • June 5, 2023 at 8:14 AM
    • KUKA Robot Forum
  • Am I writing / running KAREL the hardway?
    • Shawn Armstrong
    • April 29, 2023 at 7:10 PM
    • Fanuc Robot Forum
  • Kuka KRC4 Automatic Archive Backup
    • Latoff
    • May 8, 2021 at 7:56 PM
    • KUKA Robot Forum
  • remote motion interface
